see a message indicating we are on the new server.
Polivox VCF layout
Page 1 of 2 [48 Posts]
egasimus
PostPosted: Thu May 12, 2011 9:35 am    Post subject: Polivox VCF layout
Subject description: (currently unverified)
The (quite popular) Polivoks filter, based on the schematic by M. Bareille. Uses programmable opamp ICs (uA776, NTE888, LM4250) and runs off +/-12V or +/-15V (not tested with lower voltages yet).
MOST RECENT VERSION:
http://www.2shared.com/file/pw5qsaqe/polivoks_updated.html
Old versions:
http://www.2shared.com/file/8sijvxp1/polivoks-vcf.html
(for information only)
Untested as of 12 Aug 2011. Feel free to try it out if you dare. Cheers Smile
egasimus
PostPosted: Thu May 12, 2011 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed, I think. Now it's a bit smaller and has caps on the power rails (only 100uF electrolytics, though, didn't have room to shunt them with some 100nF ones or so). Little, if any, is left of the original abuse of curve tool, now replaced with abuse of diagonal traces. The component layout looks kinda prettier, it's fun making those:
Sebo
PostPosted: Sun May 15, 2011 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!!!
I will try it in a near future!!!
Sebo
My Music:
egasimus
PostPosted: Sat May 21, 2011 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Note that there's too little clearance around the three square pads - I'll make some room (perhaps move the pot a little) and fix that, too, but until I do, take care not to short them Smile
Sebo
PostPosted: Sat May 21, 2011 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, thank you!
Sebo
My Music:
haxster
PostPosted: Fri May 27, 2011 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you add a 50k or 100k trimmer with the outer pins going to + and - and the middle pin to a 100k resistor and add that little circuit to the Main CV Line (where all the CV's mix or meet) you will make it work universal for all Voltage Power Formats. It will act as a Cutoff Range Offset.
It is worth the extra redesigning.
egasimus
PostPosted: Mon May 30, 2011 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
That's exactly the kind of feedback I need Smile This will definitely go into the next revision.
egasimus
PostPosted: Tue Jul 12, 2011 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally:
Rolling Eyes
Sebo
PostPosted: Tue Jul 12, 2011 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
Did you tested this version?
Sebo
My Music:
egasimus
PostPosted: Thu Jul 14, 2011 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, but a guy at another forum already volunteered, and I myself got the ICs today, so it might be verified soon.
tokyomatik
Audio files: 6
PostPosted: Wed Aug 10, 2011 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
it looks pretty easy
any news? is it working? somebody tested?....
egasimus
PostPosted: Fri Aug 12, 2011 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
No :/ The guy who tried to build it only got so far, but I haven't heard from him for a while. I think he had some problems with the power supply - he's a guitar stompbox guy, just like me. I'm hopefully gonna build my own bipolar PSU soon, though, so I'll eventually get around to testing it. Sorry :/
n.d
PostPosted: Sun Jan 29, 2012 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there. Any news? Sebo? Anyone?
tokyomatik
Audio files: 6
PostPosted: Mon Jan 30, 2012 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I start to think that the only solution is trying to etch a board and see if it work.....
-minus-
PostPosted: Mon Jan 30, 2012 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Can someone actually upload an image without having to go through all the hassle of links to other sites and zip files please?
2Shared The Easiest Way To Share Files... clearly is NOT the easiest. I can't get the file to download at all. Laughing
n.d
PostPosted: Mon Jan 30, 2012 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, took me two hours to DL.
Here it is.
polivoks_updated.zip
 Filename:  polivoks_updated.zip
 Filesize:  143.08 KB
 Downloaded:  1144 Time(s)
n.d
PostPosted: Mon Jan 30, 2012 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please report back if you build it.
And egasimus, do you have the eagle - or kicad, altium, whatever- files?
Sebo
PostPosted: Tue Jan 31, 2012 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had the PCB etched for a while, but didn't had the time to solder anything yet...
Sebo
My Music:
tokyomatik
Audio files: 6
PostPosted: Thu Feb 09, 2012 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
any news about this board??
tokyomatik
Audio files: 6
PostPosted: Thu Mar 08, 2012 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
....so???? Crying or Very sad
Sebo
PostPosted: Thu Mar 08, 2012 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't do any advance Sad
Sebo
My Music:
Sebo
PostPosted: Sat Jun 02, 2012 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
I just finished my Polivoks VCF using this PCB and I can confirm it works.
I just did some mods to improve the cutoff range and the CV inputs sensitivity, but this mods are the same all people do to the Marc Bareille version.
Thanks again to egasimus for share!!!
Sebo
My Music:
LFLab
PostPosted: Mon Jun 04, 2012 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I've etched a board for this thing, but haven't found time to assemble it into a module (and since I want it to be a dual, will need to etch another board).
What mods did you do to improve cutoff range and CV input sensitivity? Will need to see if I can change the layout slightly to incorporate the changes. Would also be nice to have a euro style power connector, since I have them on the bussboards in my cabinets, that's an easy enough addition.
Edit:
Did you tie the cutoff to V- with a resistor? That's also a mod for the SSM2044 VCF, helps tremendously.
Sebo
PostPosted: Mon Jun 04, 2012 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
To imporve cutoff range I wired the side of the cutoff pot that goes to ground to -15V instead. Also changed R8 to 270K and put a 50K trimpot in series to finetune (I think I ended with a total resistance of 290K aprox).
To improve the CV sensitivity I changed R5 and R9 to 150K.
Sebo
My Music:
mrkva
PostPosted: Wed Jan 30, 2013 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
How would one adjust this shematic for +/- 12V? Thank you
