Minimoog and the tis97 transistor
Page 1 of 1 [8 Posts]
delayed
PostPosted: Tue Feb 28, 2012 3:39 am    Post subject: Minimoog and the tis97 transistor Reply with quote  Mark this post and the followings unread
What is a direct drop in replacement for the TIS97 transistor within a MiniMoog? Or is there a cheap place to buy them?
chguigoz
PostPosted: Fri Mar 02, 2012 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. You can use 2N3904 as direct replacement.
delayed
PostPosted: Sat Mar 03, 2012 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a reason the service manual only states one of the "tis" transistors to be a direct replacement with the 3904?
chguigoz
PostPosted: Sat Mar 03, 2012 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Which?
Gaetano_AU
PostPosted: Mon Jan 14, 2013 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The schematics state that:
2N3904 = TIS92
2N3906 = TIS93
BUT TIS97 = TIS97
Here are the Pinouts of the transistors for reference in case you need to try a substitute.
 Filesize:  7.43 KB
 Viewed:  8459 Time(s)
TheAncientOne
PostPosted: Mon Jan 14, 2013 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting.
If you got them from Fairchild, you got A max collector current, (Ic) of 500mA, and a max VCE of 40V. If you got them from microElectronics they specify Ic max of 200mA, but VCE of 60V.
Otherwise it's a high gain general purpose NPN with a fairly low capacitance, (1 - 4 pF).
I would be tempted to try a BC 547, (since I'm in Europe), and select one with a gain higher than 300, YMMV.
Mike
delayed
PostPosted: Mon Jan 14, 2013 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
To take a shot at my own question, it might simply be the pinout?
Gaetano_AU
PostPosted: Mon Jan 14, 2013 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
From my datasheets I get VCE = 40v for both.
