attdestroyers
Joined: Mar 29, 2012 Posts: 47 Location: Malvern, Ohio
Posted: Tue Apr 24, 2012 9:41 am Post subject:
| JingleJoe wrote: | | Banjo wrote: | Actually, the binary switches determine which decade, and the direction of the signal flow determine whether it is British, or American.
Thank you Joe for your explanations. One more question. What are your switches connected to? |
The center of the sun. Which switches? |
I think he's refering to the switches in your video of "the device." I was actually wondering the same thing. |
Joined: Jan 15, 2011 Posts: 430 Location: Montreal, Canada
Posted: Tue Apr 24, 2012 3:33 pm Post subject:
I think he was referring to more 60s British rock, this time being Pink Floyd with "Set The Controls For the Heart of the Sun"
But seriously, yeah, I was wondering about what the switches did too... |
JingleJoe
Posted: Tue Apr 24, 2012 4:20 pm Post subject:
Ah the three little toggle switches in the corner? They change the gate configuration, however it is allways changing because of the LFOs, the switches just change which Y input the LFOs go to.
With them all set "up" the LFOs are connected to 1,2 and 4, giving the effect of ring modulation. Each can be switched between a different Y input, between 1 and 6, I remember I didn't use 0 and 7 but I don't know which switch switches to which Y input but I did put some thought into it so that each switch affected one oscillator more than the others. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
JingleJoe
Posted: Sun Apr 29, 2012 1:22 pm Post subject:
I'm very glad you like the results I am allways happy to hear that someone likes my circuits
However two things:
My username is just JingleJoe, not jingler
Secondly, I can't listen to that first one, I have a headache and it is too high pitched so it is negatively lunetting my brain
Nevertheless, some good sounds there  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Posted: Mon Apr 30, 2012 3:47 am Post subject:
JingleJoe: ooops, sorry... my brain got crosswired for a moment with PHOBoS's Jingler box based on your other circuit.
I can't wait to get off work today and try a few more things with this one. Last edited by RingMad on Mon Apr 30, 2012 4:02 pm; edited 1 time in total |
forshee
Posted: Mon Apr 30, 2012 10:28 am Post subject:
| I love LUTs been thinking of writing this post for ages. If the switches switch between V+ and an input with a tie down you can get just about anything. Been working on a 5U version of this for some time lots of possibilities. Add some jk flip flops and you should be able to do just about anything. Make a few thousand of those and you've got an FPGA. |
Banjo
Joined: Sep 27, 2009 Posts: 91 Location: Atlantic county, nj, USA
Posted: Tue May 01, 2012 7:56 pm Post subject:
Sorry I haven't replied, but life gets in the way sometimes. I figured that the switches had something to do with the gates. I will keep an eye on this thread for inspiration when its time to work with the 4051 again. For now, I am trying to figure out my next project. I decided to try to do it in Reaktor first to work out the kinks. It's much better to spend an hour or two tweekng and getting it functional, than spending several hours soldering and finding out that it does not work.
Its time to build a mixer/signal router/control panel. I want to send some of the audio from my DIY synth into Reaktor , and play with it there. At least it gives me a good excuse to finally go through all of the tutorials on the program.
I will have to label one of the panels or knobs, the heart of the sun!! |
Inventor
Audio files: 267
Posted: Wed May 02, 2012 12:22 am Post subject:
I was listening to a rock and roll playlist when i encountered this thread again (after a few days hiatus in second life), and being lazy like i am i decided to just play the lunettas simultaneously with the rock. Success! Listen to "Another one Bites the Dust" by Queen along with RingMad's samples - good combination!
Which brings up an important point in listening. A lot of what we create with Lunettas are sort of missing something. Let's face facts: it is well known that Lunettas usually are way out there big time! So it only makes sense to comingle them with other music. Other new music, other conventional music, other Beethoven, whatever!
Give it a try - you'll like it!
JingleJoe
Posted: Wed May 02, 2012 4:06 am Post subject:
In the same vein as inventors suggestion there; Lunettas will be the backing in my future band, but not the core of the music.
I'm modifying an old device which never sold with a 4051 ANY gate today, results coming soon! _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
Posted: Wed May 02, 2012 4:16 am Post subject:
This device has immediately been propagated to a high place on my "modules to build list"
If i understand it right, you have 3 inputs (the LFO's) on the "Y side", the toggle switches each switch one LFO between 2 different Y inputs - right ?
Do you have pull down / up resistors on the Y inputs the LFO's are connected to ?
Have you pulled the 0 and 7 Y inputs high or low or just left them floating? _________________ Stay Cool
Mikael
http://www.mikmo.dk |
Posted: Wed May 02, 2012 5:25 am Post subject:
Inventor posted a nice clear schematic for this circuit over in his boolean sequencer thread... http://electro-music.com/forum/topic-41367.html ( look for "BS LUT 1.jpg")
But yesterday in playing around with it, I have some questions, which I was having trouble deciding if I should post here or in that thread. So here goes:
1. What purpose do the 10K resistors serve going into the DIP switch?
2. Is there any danger if one has a switch open (i.e. a logic 1 is flowing through it) and a squarewave going into the same line?
3. If I don't use any oscillators on the Y pins, and just open a few switches, it seems almost nothing gets through... i.e. I only faintly hear any audio from my A,B,C inputs coming through. As soon as I plug an oscillator into at least one Y pin, then I get something. [I admit I didn't sit down yet and figure out the particular truth table, which I suspect might have something to do with it]
James. |
Mikmo
Posted: Wed May 02, 2012 5:51 am Post subject:
My guess is that the 10K resistor is there to limit current running into the 4051 x inputs. _________________ Stay Cool
Mikael
Inventor
Audio files: 267
Posted: Wed May 02, 2012 6:24 am Post subject:
RingMad, the 10k resistors are the pull-up resistors, while the 100k resistors are pull-down. When the switch is in the open position the 100k resistor pulls the input down to ground, and when the seitch is closed a voltage divider between the 100k and the 10k forms, giving us appoximately 90% of Vdd.
This arrangement is one way to accomplish the state switching when you only have one spst switch (eight of those on an 8-DIP package). The only problem here is that if the mux is an analog mux, which i believe this one is, then the output impedance is 100k for logic zero and about 9k for logic one.
That would affect the aggregation of the signals into a stim voltage so buffering is desired. I just put an additional 100k resistor at the output for now since there is no room on the board for a buffer, but I'm thinking I need a 5VDC regulator anyway, so i might reduce the board to only 3 circuits and add the buffers. Better save than sorry.
Les
p.s. we now bring you back to your regularly scheduled thread! _________________ "Let's make noise for peace." - Kijjaz |
Posted: Wed May 02, 2012 2:26 pm Post subject:
Sorry to derail this thread with more newbie-type questions, but perhaps the info might be useful to others.
Yes, the datasheet says the 4051 is analog. I don't see anything about the output impedance.
What do you mean by "stim voltage"? As for buffering, you mean at the output? This 100k resistor at the output, that's inline or to ground?
I figured out part of my question #3 above... the DIP switches alone do nothing if the output of the 4051 is connected to Cynosure's waveshaper circuit I was using. If I take my output directly from the 4051, they work fine. This is sad... I really like the waveshaper. I don't understand why having it there is a problem.
James |
Inventor
Audio files: 267
Posted: Thu May 03, 2012 3:33 am Post subject:
| RingMad wrote: | Sorry to derail this thread with more newbie-type questions, but perhaps the info might be useful to others.
James |
RingMad, the answer to your conundrum and mine as well is buffering. Since the part is analog, what it has internally is something known as a pass gate made of two transistors, a P transistor and an N transistor with opposite values applied. Sized correctly, these become a nearly ideal analog switch. That means that whatever impedance is presented to the input appears at the output.
In this case we are applying an input impedance of either 100k (to ground) or 9k (to Vdd), so that is what appears at the output. I don't know what you are wiring to this output, but it will affect the voltage division at the input depending on what it is. As always, remember to consider the whole circuit. Do not assume that an unbuffered output is not affected by it's load. Here y ou have connected something that is reaching back through the analog switch and affecting the input circuitry, and therefore the output value. With buffering, however, this is not an issue.
As for the stim voltage, my Boolean sequencer is designed to drive the inputs of a Karplus Strong board which has a stim pulse, that is all. I hope that explanation helped, and please ask again if you have any more questions.
Posted: Thu May 03, 2012 3:45 pm Post subject:
Indeed, buffering fixed the problem, thanks Les!
And, I finally figured out what you meant by "stim voltage"... stimulation!
Still having lots of fun with this circuit, making several recordings. Probably will put more on my soundcloud soon. Definitely this guy will be part of my suitcase Lunetta. And maybe even a box to itself.
James. |
JingleJoe
Posted: Sat May 05, 2012 1:12 pm Post subject:
I feel the need to mention, as it is relevant to some of your queries chaps, that I seem to recall that the resistance of the Y inputs to X were stated on the datasheet and changed a little for different supply voltages. I think they were about 300 ohms in general but check the datasheets, I may be wrong.
Ringmad, to elaborate on your 3 earlier questions, the 4051 is like switches, if nothing is connected it's literally like having a bit of wire that goes nowhere You need to add a pull down/up resistor or some kind of voltage. Remember also that logic 1 is acctually a voltage and connecting it directly to another one would do strange and possibly explodey things, I would advise you mix them passively through 100k resistors or through a gate; e.g. a diode OR gate. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Posted: Sun May 13, 2012 6:44 am Post subject:
Well, nothing's exploded yet, except the number of recordings I made using this ANY gate (and usually going through Cynosure's triangle waveshaper)! I think it's up to 24 now, which is the most I've done for any Lunetta module.
I've selected and edited some of the best and thus there are 5 new CMOSnippets on my soundcloud if anyone cares to listen... http://soundcloud.com/jamesschid
Thanks muchly again JingleJoe!
James |
JingleJoe
Posted: Sun May 13, 2012 3:05 pm Post subject:
They all sound great I could hear my ANY gate in a few of them Carry on the good work, I'll say it again, I am always happy to provide weird sound circuits  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
efabric
Joined: Jan 05, 2012 Posts: 19 Location: Caen, France
Posted: Tue Apr 23, 2013 7:18 am Post subject:
I feel like you're feeding the beast the wrong way...
Isn't the 4051 a digitally controlled switch ?
If you feed Y inputs with eight tuned oscillators like this :
Y0 : C
Y1 : D
Y2 : E
Y3 : F
Y4 : G
Y5 : A
Y6 : B
Y7 : Octave C, or no note at all (ground)
(of any combination of eight loved vintage 60's bands, 8 tape tracks, etc.)
And your A, B, and C inputs with LFOs,
You can collect at output X a random melody generator, or random cut playlist, or track selector...
If you feed A, B, and C with audio frequencies, your multiplexor is too much out of control, and displays only an audio fragment of a lfo... _________________ My Scoopit DIY Synths and Schematics curation |
JingleJoe
Posted: Tue Apr 23, 2013 12:48 pm Post subject:
efrabic, you have missed the point completely.
go back, read everything again.
Phobos, you have not missed the point at all, you have harnessed the very core of the idea. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
efabric
Posted: Tue Apr 23, 2013 1:52 pm Post subject:
I don't think I missed the point. Perhaps only the use and effect of your three switches ?
CMOSnippet 028: Otilibous by JamesSchid illustrates what I said. I haven't heard it before cause internet restrictions.
No need to read everything twice.
Another Idea : If you connect Y points with a packed resistor array , the X output can also send a random (or digitally controlled) Control Voltage to feed another VCO...
Resistor arrays contains matched resistors, simple to solder in parallel and easy to find in electronics garbadge... _________________ My Scoopit DIY Synths and Schematics curation |
Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Tue Apr 23, 2013 3:53 pm Post subject:
I was going through my parts drawer (very untidy at the moment) and I found a few spare 4051's and 4052's. Now I have something cool to do with them that I wasn't expecting...
thanks JingleJoe and PHOboS _________________ Zontar Prevails! |
