amp for a little speaker in the Sound Lab
Page 1 of 1 [4 Posts]
vintage
PostPosted: Thu Mar 24, 2005 5:20 am    Post subject: amp for a little speaker in the Sound Lab Reply with quote  Mark this post and the followings unread
Hi again!
I'm planning on integrating a little speaker into my Sound Lab, so when it's not connected to outside P.A., I can still practice (even with a plugger for headphones). I saw a photo of a Sound Lab project inside a little suitcase, Synthi A style, in the Sound Lab site with a speaker integrated.
Do you know of a simple and good schematic for a little amp to feed the speaker and the headphones?
I found some, but maybe you guys know of a better one to build.
thanks a lot.
Mike Walters
PostPosted: Thu Mar 24, 2005 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Incidently, my SoundLab can drive a pair of headphones thru its normal output. I have an old set of mono Telex headphones used for schools back in the day. It doesn't work well, and I have to put the master volume to 11, but it's surely audible!
Best bet would be to build a small preamp. There are tons of schematics on line that use simple op amps.
-Mike Walters
www.mysterycircuits.com
killsurfcity
PostPosted: Thu Apr 14, 2005 6:06 am    Post subject: Re: amp for a little speaker in the Sound Lab Reply with quote  Mark this post and the followings unread
i don't know if you've found a suitable ore-amp yet, but their are some good ones on this site:
http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
scroll down to "boost-o-rama", or even further to "utility boost".
i have built one of the utility boost ones a bunch of times, and it's great, just what you need to push just about any signal.
hope this helps,
-et-
vintage
PostPosted: Thu Apr 14, 2005 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but I already used another simple design, works perfectly. Thank you anyway!
