 Forum index » Clavia Nord Modular » G2 extended patches
Some new modules and patches made with that
Page 1 of 3 [55 Posts]
Goto page: 1, 2, 3 Next
brunov
PostPosted: Sun Jul 08, 2012 2:51 am    Post subject: Some new modules and patches made with that Reply with quote  Mark this post and the followings unread
Hey, I found some extra modules in the editor that actually seem to work!
It's a "resonator" module and "driver" module. I don't know exactly how to use them or connect them, you can see them below in the screenshot.
There are some more modules that never made it into the G2, I tried some of them, but not all seem to work. Maybe because they don't exist in the G2 firmware, or maybe I haven't formatted the message correctly.
ModuleType ShortName
AR-Env
AudioIn
Blue2Red, seems to be a testing module
BusIn
ClkDivFix
35 Driver -> Works!
EnvDX
LfoD
Mixer6-1A
Mixer6-1B
OutBusA
OutBusB
PeakFollow
101 PolarFade -> Doesn't seem to work
120 PolarPan -> Doesn't seem to work
10 PulseOsc -> Doesn't seem to work
Red2Blue
56 Resonator -> Works!
207 RndChaos -> Doesn't seem to work
RndDistr
RndState
RndStep
SeqA
104 ShelvEQ
14 SyncOsc -> Doesn't seem to work
The bottom screenshot shows some of the modules I tried sofar, so only the Resonator and the Driver worked, but interesting none the less!
I wonder what the driver is supposed to do...
[NOTE by Blue Hell: this was split off from http://electro-music.com/forum/topic-48872.html ]
 Filesize:  63.45 KB
 Viewed:  1295 Time(s)
 Filesize:  56.49 KB
 Viewed:  1248 Time(s)
My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
My new G2 editor FMX: http://www.bverhue.nl/g2dev/?page_id=17
Source code: https://github.com/BVerhue/nord_g2_editor
dorremifasol
G2 patch files: 49
PostPosted: Sun Jul 08, 2012 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing discovery! I suppose they expected the G2 to be successful and add / finish lots of interesting modules over time.
Albert
Scot Solida
PostPosted: Sun Jul 08, 2012 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Seems like physical modeling. The Driver is clearly an exciter model, used probably to excite the Resonator (which is also likely to be a typical PM resonator - it's set to strings at the moment). Strange that it lists pretty much wind/brass exciters, while the resonator has strings added in (the "tube" would represent the body of the wind/horn). There is a bow exciter listed, so that must be it. Probably a short burst of noise could be used in lieu of a proper pluck exciter.
This is exciting stuff, especially given that A: they work! and B: my long lost G2 returns to me next week, so I can play with 'em.
Nicely done, sir!
PostPosted: Sun Jul 08, 2012 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
The polar thingies once were available in some beta ... can't recall why they were retracted exactly ... anyway, there might be some code too in old beta's, just too bad they were handed out under a non disclosure agreement.
brunov
PostPosted: Sun Jul 08, 2012 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I suppose the "drive" inputs/outputs are meant to be chained like so.
These two modules seem to be the only ones that work. That's a pity, the RndChaos, PulsOsc and SyncOsc seem interesting also.
I'll try and make an intermediate release soon that include these two new modules.
 Filesize:  63.9 KB
 Viewed:  61959 Time(s)
brunov
PostPosted: Sun Jul 08, 2012 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I made a release 0.24 that includes these modules.
If you already installed the OS editor, you only have to download the zip and extract it somewhere on disk.
Otherwise you'll have to install the libusb-win32, then please read and follow the install instructions in the readme file carefully.
veta
PostPosted: Sun Jul 08, 2012 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
yes. it would be terrible if that code got out in the wild somehow.
if some unscrupulous individual were to post it somewhere anonymously...
well, i would hate to see something like that happen to clavia.
especially given their impeccable track record of supporting their customers, fixing bugs, updating the editor, etc.
brunov: you are doing amazing work. is there any chance of a mac version of your editor?
PostPosted: Sun Jul 08, 2012 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Jul 08, 2012 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow! Great find!
Please do us a favor. Save a working patch built with the Driver and Resonator modules and post it here. I would like to see if the G2 Editor (mine is version 1.40) can load the patch and edit it. If that works, it might be possible to have a template patch that contains all of these working hidden modules that could be used with the G2 Editor.
My theory is that these hidden modules can be edited once they are in a patch, it’s just that the G2 Editor software just does not allow you to *add* these hidden modules while editing a patch.
This is all just very good work brunov. Bravo!
varice
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Jul 08, 2012 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
especially given their impeccable track record of supporting their customers, fixing bugs, updating the editor, etc....
Oh my, that would be just so terrible!!!! Laughing
varice
PostPosted: Sun Jul 08, 2012 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked cheers
That's amazing! If these modules turn out to be usable it's a more important find than the Higgs particle!
Ok I exaggarate (though just a little bit), but really, awesome work! Very Happy Very Happy
brunov
PostPosted: Sun Jul 08, 2012 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Varice, I'm going to upload the patch but I'll be surprised if it works.
I'm on G2 Editor and OS version 1.62 and when I try to load it, I get an error message "Module doesnt exist."
For the modules we're dependend on the G2 OS, there's no way we can make changes to the OS. Somehow they forgot to take these two modules out of the OS or forgot to put them in the editor.
With these other modules, changes are slim that they exist somewhere in the OS. The only thing I do is to send a message from the editor "Create module type 56" to the G2, for the driver and resonater this worked but and for all the others the G2 responds with "Error 3", which probably means "Module doesn't exist".
You'll get some Idea of the modules that where planned when you look at the little map of module icons.
Veta: I hope to make a mac version someday, but that won't be any time soon. Maybe this winter I'll get some time to really do some serious work again on the editor.
I uploaded a small example of some sounds I made with the patch.
Resonator.wav
 Filename:  Resonator.wav
 Filesize:  4.5 MB
 Downloaded:  1690 Time(s)
Resonator.pch2
 Filename:  Resonator.pch2
 Filesize:  1.76 KB
 Downloaded:  4720 Time(s)
 Filename:  module_map.bmp
 Filesize:  339.35 KB
 Downloaded:  1129 Time(s)
brunov
PostPosted: Sun Jul 08, 2012 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Antimon wrote:
If these modules turn out to be usable it's a more important find than the Higgs particle!Very Happy
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Jul 08, 2012 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the modules we're dependend on the G2 OS, there's no way we can make changes to the OS. Somehow they forgot to take these two modules out of the OS or forgot to put them in the editor...
brunov, thanks for the test patch. I couldn’t load it with the v1.40 Editor either. I got the same error message. Rats!!!
Well, I’ll just go ahead and install your open source editor then to check out these hidden modules. Thanks again for your excellent work Exclamation
varice
veta
PostPosted: Sun Jul 08, 2012 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
the resonator sounds great in the wav you posted, brunov.
perhaps this discovery deserves it's own thread?
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Jul 08, 2012 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
IMHO, I would think so, especially for posting patches using these hidden modules that are not compatible with the Clavia G2 Editor…
varice
drapdap
PostPosted: Mon Jul 09, 2012 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Very Happy excellent work Bruno!
it does sound neat...
Also could make Bruno's Development sticky, so it stays on top?
btw. the fixed clockdivider was active till 1.12 or something, than they changed it to the variable one, so that one should work too, maybe a bit pointless to have it, but oh well, luxury! Very Happy
brunov
PostPosted: Mon Jul 09, 2012 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried the static clockdivider but sadly no, g2 won't have it. I guess we just have to be happy with whatever falls our way.
Alle these other modules have a distinct "test"/"prototype"/"not really ready" feeling about them, but I'm really happy with the driver/resonator.
The driver has 4 modes "Reed", "Bow", "Lips" and "Mallet" but for one reason or another the last two are crossed out. Maybe they don't want us to use them...
Then the resonater has 5 algorithms: 2 string and 3 tubes.
They are quite expensive DSP wise, can only have 6 per patch on an expanded G2 and the you have to devide them over VA and FX location.
But if you patch'm like this, taking the input from another slot, you can make some really big sounds. Razz
 Filesize:  200.91 KB
 Viewed:  1081 Time(s)
drapdap
PostPosted: Tue Jul 10, 2012 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, no dsp usage meter in the open source editor??? 'Twisted Evil'
shure, but looking at the list one can`t help wondering...
EnvDX?
maybe a 16 stage envelope? Very Happy
about the resonators, i remember Tombola patched them up, i wonder how they compare (i'm not near my engine now, but soon, can't wait to try them hidden modules) anyway, here's the thread...
http://electro-music.com/forum/topic-12177.html
there's a bit of misconception about resonators, in computer/dsp world they mean these tracked/excited oscillator/delay whatevers, (Very Happy) and in
analog modular world they mean bandpass filters, (i guess) since the korg ps3200 and the polymoog... always confuses me.
anyway, keep us updated Bruno! this is exciting!
Audio files: 226
PostPosted: Tue Jul 10, 2012 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made this topic Sticky, as suggested. Thanks...
Since the open source editor is mentioned on the very first page of this topic, I'm not sure what splitting would accomplish.
drapdap
PostPosted: Wed Jul 11, 2012 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
wonderful, thanks Mosc!
brunov
PostPosted: Wed Jul 11, 2012 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I did a little compare, they sound quite different. I bit more rough maybe. They are very sensitive around the self-oscillating frequency, especially the "tube2" algorithm, which can result in massive clipping of the output.
I'm very happy that it's these two modules that work, since they might be difficult to reproduce with other modules, so really interested what you can make out of these. Very Happy
Maybe you can als figure out what to do with the "Excitation" input of the driver module.
drapdap wrote:
EnvDX? maybe a 16 stage envelope?
I would love to try it out, but I can't find the corresponding icon in de module icon map. When it's on the module icon map I can figure out which module type number I have to send to the G2.
Well, eh, sorry, no, that requires solving a bit of a puzzle that's beyond me at the moment.
I had a try earlier, here's a tabel in which I've put the data out of "resources used" message dat the G2 sends after adding a module.
https://docs.google.com/spreadsheet/ccc?key=0AqgnqbP0tPvDdGpnNW80X2RlRVVXR08xUHlvV0RiRlE
I figured out that there are 10 or 11 parameters (resources, delay memory for example) and out of these the "Cycles" and "Memory" should be calculated. But the problems is, I don't know what the parameters are and what there bounds are.
So, have to do without for the moment, unless maybe someone else can see any logic in this table?
JLS
G2 patch files: 316
PostPosted: Thu Jul 19, 2012 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi brunov
Nice work two new modules is great for me.
Please some info about RndChaos module - this sound interesting - please test it again - true not working ? any chance ?
Many thanks info and your great work.
Kamil
https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/
Roland Kuit
G2 patch files: 127
PostPosted: Thu Jul 19, 2012 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic work Very Happy
anigbrowl
G2 patch files: 5
PostPosted: Sun Jul 29, 2012 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing! I just downloaded the new version, and although I have some difficulty with the libUSB (because I am using AMD64?) I am looking forward to try the new modules.
Shocked
