tiptaptempo
Joined: Jul 15, 2012 Posts: 53 Location: Nantes, France
G2 patch files: 16
Posted: Sun Jul 15, 2012 9:44 am Post subject:
Audio in trigger Subject description: New to Nording, need vhelp |
I'm completely new to Nording and have a project about drum triggers and nord G2x. Actually i want to do a "Tribute to Duracell", a man who triggered his drum into a G2. I ring him on the phone, he says that this will be a little bit difficult, but no matter !
The fact that is i've a new patch, but there is no sound at all : Any one can tell me why ? (I guess it's just a beginner error ; shame on me ... )
I have drum triggers, they go into the g2 as "audio in", i try to put in sequencer with notes. When i hit the drum in the patch, the step of te sequencer goes into the next step, but then, no sound to my headphone.
Thank you for any reponse.
reg from nantes
Description: |
 Download (listen) |
Filename: |
Regis Trigger.pch2 |
Filesize: |
1.34 KB |
Downloaded: |
4320 Time(s) |
Joined: Apr 03, 2004 Posts: 24476 Location: The Netherlands, Enschede
Posted: Sun Jul 15, 2012 10:08 am Post subject:
tiptap
what do you have on the R input? as that is the signal that goes through the filter and should become audible ... _________________ Jan
tiptaptempo
G2 patch files: 16
Posted: Sun Jul 15, 2012 10:42 am Post subject:
trigger in |
Hi blue hell,
Sorry, but i've misunderstanding your question ... i'm really completely new to nording ... it'll take time to do what i want with a G2.
The right input is linked with a filter nord and then a 2 out module. |
Posted: Sun Jul 15, 2012 10:51 am Post subject:
What I meant is what have you plugged in into the G2 externally on the R input; you now have a filter, which on its own will not make a sound but it will change a sound that comes in, and your external signal goes to the filter ...
ok .. maybe just replace the filer with an oscillator, then you will have sound. _________________ Jan
tiptaptempo
G2 patch files: 16
Posted: Sun Jul 15, 2012 11:16 am Post subject:
Thank you,
I know i must do ti myself, you opened my eyes about filters, it can make change sound only if a signal comes in this types of modules.
I've plugged a drum pad as audio in to the phsysical inputs of my g2, but i'm not sure it's a good reponse ...
I must read more consciouscly my manual before asking questions ... |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
tiptaptempo
G2 patch files: 16
Posted: Sun Jul 15, 2012 2:06 pm Post subject:
Hi Roland,
That's such an honor to have a reply from you ! i believe i had reading one of your very complete blog to the nord modular. It stills fresh and hard for me, because of english language and technical requirements.
The patch you sent me works a little better, thank you, I replaced the Fx in module by ""Audio in module. It reacts, but not properly as i was expecting.
It makes a sound like when you hit with your finger a dynamic microphone shure sm 57.
I use a electronic pad (type of cheap yamaha) ,
I think i must use preamplification to have the note sound.
I'll use snare triggers with accoustic drum tomorow.
My main objective with my recent G2 is to dedicate a tribute to Andre Duracell http://www.youtube.com/watch?v=2QfwKqy3LyY
I'll reach the top ! one day for sure even if it looks to me ... |
Roland Kuit
G2 patch files: 127
tiptaptempo
G2 patch files: 16
Posted: Thu Jul 19, 2012 3:41 am Post subject:
Hi Rob,
Thank you for this help,
I replaced "Fx in" by "2 in", I've a cheap drum pad that i linked in the "audio in" physical nord output. It makes sound but still not like as i was expecting .
I'm reading all your posts to have a better feel of digital sound synthesis.
Then i might post such cleverer questions about Triggers.
reg from nantes |
Roland Kuit
G2 patch files: 127
Posted: Thu Jul 19, 2012 5:01 am Post subject:
Rob??? |
tiptaptempo
G2 patch files: 16
Posted: Thu Jul 19, 2012 5:54 am Post subject:
Roland Kuit wrote: | Rob??? |
sorry ...  |
tiptaptempo
G2 patch files: 16
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sun Jul 22, 2012 3:05 am Post subject:
Re: Tribute to duracell |
tiptaptempo wrote: | Then i tried to replace the Keyboard module ( section "in/out") by a "2 in" module. I've got a snare drum trigger into the physics audio in of the g2.
It don't react, and i'm asking me why ? |
The 2 in module is what you need to get audio signal into your patch.
Audio is not very suitable for trigger. One solution would be to connect the "2 in" output to a logic pulse module, then use the pulse output to step the sequencer. Experiment with pulse time to get best results.
You should be able to use amplifier modules to boost the signal from the "2 in" if required. |
tiptaptempo
G2 patch files: 16
ian-s
Audio files: 42
G2 patch files: 626
Roland Kuit
G2 patch files: 127
Roland Kuit
G2 patch files: 127
tiptaptempo
G2 patch files: 16
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Jul 24, 2012 2:15 pm Post subject:
Your patch has the envelope trigger connected to the blue 'note out' of the sequencer. It needs to be connected to the yellow 'trigger/gate out'. You will need to adjust the attack decay times because the trigger is a very narrow pulse. You might get a better result using and AHD envelope where you can adjust the note length with the H knob.
Another way to deal with the note length issue might be to use a foot switch so that a note holds till you take your foot off the switch but I never tried that. |
Roland Kuit
G2 patch files: 127
tiptaptempo
G2 patch files: 16
Posted: Mon Jul 30, 2012 8:12 am Post subject:
Roland Kuit wrote: | I adjusted the trigger. Replace this little drums with your audio in module. |
Hi Roland,
I'm gonna order your Sound Lab I e book this week ... Too much things to understand as a simple drummer ...
Do you think that your E book will help me for this particular project ?
I prepare my coffee ...
I would like also to ask something about velocity.
A the point of my project, when i hit the snare or bass drums it works fine and it reacts with the note sequencer. Now this is time for adjusting with velocity.
I hear it's can be done with a logic delay and a sample and hold module ? |
Roland Kuit
G2 patch files: 127
