homers
Posted: Mon Sep 03, 2012 4:01 pm Post subject:
G2X (OS1.62) keeps resetting after power up. |
My G2X (OS 1.62, no PC attached, initial patches which came with 1.62) keeps resetting himself after power up.
Sometimes when I do a power cycle (on/off/on) multiple times it starts working again.
Unfortunately it falls back into resetting when I'm loading a new a new patch from the G2X memory in one of the slots, not always but quite often.
I wasn't sure if I should but the topic here or into the bug part.
Any ideas? |
Joined: Apr 03, 2004 Posts: 24653 Location: The Netherlands, Enschede
Audio files: 326
Posted: Mon Sep 03, 2012 4:17 pm Post subject:
homers. Annoying problem
If I were me .. I'd open it up and look .. maybe something is loose?
Could it be your power is low, like say 90V instead of 110?
Just some wild thoughts. _________________ Jan
homers
Posted: Mon Sep 03, 2012 4:24 pm Post subject:
| I already checked the connections and the switch on the power supply shows 110V other synths on the same outlet have no problems. |
Audio files: 326
Posted: Mon Sep 03, 2012 4:29 pm Post subject:
As in you opened it up? _________________ Jan
homers
Posted: Mon Sep 03, 2012 4:50 pm Post subject:
| Yep. |
Audio files: 326
Posted: Mon Sep 03, 2012 4:53 pm Post subject:
Damn, I'd have to think now
Pull cables and reseat 'm? _________________ Jan
homers
Posted: Mon Sep 03, 2012 4:55 pm Post subject:
| Ok will do and report back tomorrow. |
homers
Posted: Mon Sep 03, 2012 5:41 pm Post subject:
Couldn't wait until tomorrow open the G2X unplugged all ribbon cables on both sides not only at the mainboard side as I did it the last time and it looks good so far
Let's for how long it will last. |
Derek Cook
Posted: Fri Sep 14, 2012 12:14 am Post subject:
Hopefully a long time.
Connectors can get oxidized over time. The other possiblilty with the G2 engine as it runs quite warm (mine does anyway) is thermal creep of connectors if there are no retaining lugs/straps. As things heat up and cool down they expand and contract which can gradually work connectors/pins out of sockets over time. It happens with chips as well if they are socketed, so it's always giving them a firm push when fault finding. _________________ Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com |
paalolav
Posted: Mon Sep 17, 2012 9:04 am Post subject:
| I had the same problem with my G2X. Talked to a tech who recomended me to change the PSU, which I did. I had a spare one from a Nord Stage. It has worked perfectly ever since. Knock on wood! |
homers
Posted: Mon Sep 17, 2012 9:08 am Post subject:
I forgot to mention, that after I put the G2X back in the rack it happened again.
I also found a trick, while doing the endless reboot you have to steady turn one of the continues controller during the reboot which will break the cycle eventually.
It is really strange, I like the idea with the psu but I don't have any spare parts, any idea where I can get one? Last edited by homers on Mon Sep 17, 2012 9:17 am; edited 1 time in total |
paalolav
Posted: Mon Sep 17, 2012 9:12 am Post subject:
| Check with your local Clavia dealer. Good luck! |
paalolav
Posted: Mon Jan 14, 2013 6:55 am Post subject:
| Any updates? |
paalolav
Posted: Mon Jan 27, 2014 7:16 am Post subject:
| I had the same issue again. After consultation with the Clavia rep in Norway, I tried resetting the synth and installing firmware 1.40. It is now cured! Knock on wood... |
Scot Solida
Joined: Oct 24, 2009 Posts: 100 Location: Hutchinson Kansas
Posted: Tue Mar 25, 2014 7:54 pm Post subject:
| I would love to know how you reset it. I have a brain-boggled G2 prototype unit and no reset procedure I have tried worked. Maybe your procedurewould be different from those i have tried... |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Tue Mar 25, 2014 9:13 pm Post subject:
Scot,
If factory software resets have not solved your problem, then it may be a hardware problem instead. I’ve had a few other synths (and other electronics) in the past that had intermittent problems that turned out to be just poor power supply or interconnect cable connections. Over time, it is not unusual that the contacts of the connectors may oxidize and even build up a little corrosion. I would recommend that you open your G2 and try unplugging and replugging the cable at both ends between the power supply and main PCB (with the mains AC power cord unplugged first of course ). _________________ varice |
Scot Solida
Posted: Wed Mar 26, 2014 4:50 am Post subject:
Thanks varice. Yes, I have done those things… I even had a new ribbon cable made to replace the one that connected the front panel to the main board.
It was my own fault that it died. I was warned that it might not respond well to any firmware updates and those warnings were not wrong. My front panel is pretty much completely useless. The keyboard works, but most of the buttons do not and most of the knobs either do not work or behave in unexpected ways.
Clavia suggested reinstalling the original firmware that was sent with the thing, but that didn't work, either. In fact, each time I tried, i got different, varying results (some knobs would work after some attempts, but not others).
I can still control it with the software editor, so it behaves as the equivalent of a G2 Engine at this point. |
paalolav
Posted: Tue Apr 01, 2014 11:53 am Post subject:
| Scot Solida wrote: | | I would love to know how you reset it. I have a brain-boggled G2 prototype unit and no reset procedure I have tried worked. Maybe your procedurewould be different from those i have tried... |
Ahh - can't remember right now, but I found it by searching this forum! It's a combination of three buttons held down while powering the G2 on. |
homers
Posted: Sun Jun 08, 2014 1:35 pm Post subject:
Sorry for the late reply guys.
The first solution for my problem was to replace the fuse with the proper value. My G2 is an European Model but inside of the G2 there is a switch to change the input voltage to 110V which I did. Of course I forgot to replace the fuse with a higher one due to the higher current. After I changed that it worked well the last time when I worked with it a couple of months ago. But today it went back doing the looping  |
homers
Posted: Fri Jun 20, 2014 3:31 pm Post subject:
I found out that the G2 works fine when as long as the G2 editor is not running. When I start the editor the g2 starts reseting himself after a 5~10mins (haven't stopped the time yet).
Any ideas? |
homers
Posted: Sat May 02, 2015 1:50 pm Post subject:
Ok, I'm back in Germany (240V ).
I think I found the issue why my g2x is behaving this strange.
After I finally decided to remove the voice expansion board the g2x started to work fine, no reboots/freezes with or without the g2x connected to the editor.
Have any of you information about faulty expansions boards in the first g2x which were shipped out? |
Audio files: 326
Posted: Sat May 02, 2015 2:30 pm Post subject:
Hmm .. in the beginning .. but that was with prototypes I think .. there were issues with the expansion .. but this is from rumors only ... sorry that's all I know. _________________ Jan
homers
Posted: Wed May 06, 2015 3:45 am Post subject:
I already resoldert the two connectors on the soldering side of the board but no luck so far. Maybe I should try the same with the mainboard?
I hope it is just a cold soldering because the G2X was working from time to time. I keep you posted. |
kslight
Posted: Sun May 24, 2015 11:22 am Post subject:
I don't own a G2 anymore, but when I had one sometimes it would be weird when connected to the PC. I replaced the USB port and worked perfectly until I sold it.
Very simple job for any soldering monkey to do, and its a standard USB type B port. |
