Matsushita Delay Line EFD-EN645
Page 1 of 1 [6 Posts]
axl
PostPosted: Tue Nov 06, 2012 10:08 am    Post subject: Matsushita Delay Line EFD-EN645
Subject description: any info about this ic??
Hello !
today i found in a old tv this Ic's.
Can't find anything online No datasheet no projects etc.....
Someone know how does it works?
Is it suitable for audio pourpose??
Thanks
Alex
 Filesize:  3.32 KB
 Viewed:  15518 Time(s)
DrJustice
PostPosted: Tue Nov 06, 2012 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The most concise info I could find was: "DELAY LINE 64uS EFD-EN645 - Quartz, Ker.filter, stb.".
64uS happens to be the scan line interval in PAL and NTSC televisions.
In conclusion, unless you specifically need a 64uS analogue delay, I can't see much use for it in audio projects.
DJ
axl
PostPosted: Wed Nov 07, 2012 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
kind of optocouple right?????
Thanks Dr.justice
DrJustice
PostPosted: Wed Nov 07, 2012 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
From the little info I found ("Quartz, Ker.filter, stb") it's probably based on a quartz crystal, like the image below (from this wiki article).
Hey - it even looks the same w.r.t. packaging and pinout and has the same specs Smile
DJ
axl
PostPosted: Thu Nov 08, 2012 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uhm.......... will be nice to see the freq response of this stuff.....
the piezo usually have strange cool sounds.....
cloudscapes
PostPosted: Fri Nov 09, 2012 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
This is not an audio delay line in that it doesn't involve memory. You can't delay audio, just electric signals a few millionth's of a second.
Sonic Crayon DIY effects lab
