today> Twyndyllyngs Chez Mosc
synthesizer trio
Page 1 of 1 [25 Posts]
uuuuu
PostPosted: Sat Nov 24, 2012 12:50 pm    Post subject: synthesizer trio
Subject description: :)
Hello
synth trio designation
uuuuu
PostPosted: Sat Nov 24, 2012 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
xxx
uuuuu
PostPosted: Sat Nov 24, 2012 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
iiii
PostPosted: Sat Nov 24, 2012 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
The cost of posts and knobs can often be worth that much alone, but if you find some cheap pots and skip the knobs then you might be able to put something together in that price range.
Have a look in the Lunetta thread for some ideas. You should be able to do a baby 4 with a simple filter and 7555 EG for that much.
JacobWatters.com
uuuuu
PostPosted: Sat Nov 24, 2012 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
kkk
PostPosted: Sat Nov 24, 2012 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Baby 10 (limit it to less steps if you can't afford all the pots):
http://i210.photobucket.com/albums/bb292/frequencycentral/baby10.jpg
7555 EG that runs off a +5V supply:
http://www.jacobwatters.com/images/synth/ad_7555_jovianpyx.gif
Some simple active filters for the EG to control. Use one that has a CV input:
http://electro-music.com/forum/topic-43897.html
I think you could fit the EG buffer and invertor and the filter all on one LM324.
JacobWatters.com
uuuuu
PostPosted: Sat Nov 24, 2012 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
TTTTTTTTTTT
PostPosted: Sat Nov 24, 2012 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
haney wrote:
the greatest human being to ever live!! this guy!!!!
Possibly Very Happy
haney wrote:
U have a band out there????
No band. I just play with myself Laughing
haney wrote:
give me a full working schematic for 10 dollars paypal
I would have to breadboard it and test it out, and I don't have time for that right now.
haney wrote:
no thinking required.
Learning this stuff is half the fun. Then next time you can figure it out on your own, and pretty soon be giving schematics to other noobs here in the forums.
JacobWatters.com
-minus-
PostPosted: Sat Nov 24, 2012 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my suggestion. It's going to be hard to do for $20-$40. I'd be making one of these:
http://www.musicfromouterspace.com/forums.html?CATPARTNO=ALIENSCREAMERKITANDPANEL&PROJARG=ALIENSCREAMER%2FALIENSCREAMER.php&MAINTAB=CATALOG&VPW=1261&VPH=761
Ok, so it's $70... and you will need a soldering iron and solder too, but it looks like it comes with everything you need, even a panel. At least you know all the parts are there, and the circuit will work.
uuuuu
PostPosted: Sun Nov 25, 2012 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
sssssssssssss
uuuuu
PostPosted: Sun Nov 25, 2012 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
xxxxx
-minus-
PostPosted: Sun Nov 25, 2012 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
haney wrote:
I have an emergency that i need it
Laughing I know the feeling. I've had alarm bells ringing here for 4 years and I still haven't finished the synth I want/need!
I'm not sure what you define as a 'synth'. There are plenty of little noise makers out there you could make. The budget is the problem. You aren't going to get much in terms of a full synth with that. I'd be looking at an Atari Punk Console or a square wave drone machine. The expensive part is hardware. Potentiometers, switches, sockets etc. You say you want to plug it into an amplifier, so there goes 1 socket. You need a battery clip. That would be around a tenth of your budget gone already. Potentiometers cost money. You can't really have more than say four or five with your budget. Then there's some kind of board to build it on. IC's, resistors, capacitors etc. And an enclosure of some sort.
I'd be looking in the Lunetta forum. You could probably make some simple noise maker out of a couple of IC's and some passives. have a look around there.
Perhaps there is a magic chip somewhere to give you a fully fledged synth. I haven't found it yet! Laughing
uuuuu
PostPosted: Sun Nov 25, 2012 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
YYYY
PostPosted: Sun Nov 25, 2012 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Closest I've seen are the CEM chips, and they'll blow the hell out of that budget by themselves, well before you get to all the physical stuff you were pointing out.
syntherjack
PostPosted: Sun Nov 25, 2012 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hallo,
try WP-20 synth. Not very popular, a little outdated, but really fun to tweak. I build it much below 20$ (using chinese pots, but still below 20$). You can find some demo on youtube.
Jack
RF
Audio files: 28
PostPosted: Sun Nov 25, 2012 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's something to try. Although results are varied from others who have built it.
It's not 1 volt per octave. Wink and is a bit unruly.
You need a CV and Gate/trigger source to get any sound from it.
Repeat
Sequencer...CV Keyboard or other CV/Gate or Trigger source.
Here it is using a baby 10 sequencer with a trigger mod.
http://www.youtube.com/watch?feature=player_embedded&v=Z-ZdbbtVmAM
Good luck
bruce[/url]
 Filesize:  163.74 KB
 Viewed:  397 Time(s)
www.sdiy.org/rfeng
PostPosted: Sun Nov 25, 2012 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
The WP-20 looks pretty interesting; that's basically an even more simplified version of the same idea as the Soundlab, which I've been building lately.
RotomotioN
PostPosted: Wed Mar 06, 2013 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can spot a couple of omissions in that schematic.
First: VR2 appears to be a normal fixed resistor, it should probably be wired like VR1.
Second: no mentioning what IC's were used, which makes it impossible to build.
PostPosted: Wed Mar 06, 2013 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
My guess for the chips is a standard op amp (TL07X) and a hex inverter, probably one of the schmitt trigger ones, so a CD40106.
analog_backlash
Audio files: 21
PostPosted: Wed Mar 06, 2013 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also:
(1) You should connect unused inverter pins to 0V (5 and 9 in this case).
(2) The op-amp pins suggest that a dual op-amp has been used (e.g. a TL072). If you use this, I would connect the spare op-amp up with the inverting input connected to the output (pins 6 and 7) and the non-inverting input to the junction on R13, R14 and C12 (pin 5 - this is at half the supply voltage). Alternatively, If you don't want a wasted op-amp, you could use a single op-amp (e,g, TL071) - pins 2, 3 and 4 as per diagram, pin 7 to positive (not pin 8 ) and pin 6 as the output (not pin 1).
Gary
PostPosted: Wed Mar 06, 2013 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking at this again that fixed resistor may be deliberate as well, since that's the control voltage side. Not clear whether the mistake is omitting the rheostat bits of a pot or naming the resistor incorrectly. I haven't build this circuit so I can't say for sure....
analog_backlash
Audio files: 21
PostPosted: Thu Mar 07, 2013 3:30 am    Post subject: haney Reply with quote  Mark this post and the followings unread
BTW, I think uuuuu = haney and he (she?) has been playing silly buggers (as we English say). It doesn't matter really - he (she) can only screw up their own postings...
Audio files: 309
PostPosted: Thu Mar 07, 2013 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm .. uuuuu felt lonely? Shocked
richardc64
Audio files: 26
PostPosted: Thu Mar 07, 2013 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
CV In controls the frequency of both oscillators thru "starvation." A "master pitch", if you will. VR1 makes the second oscillator variable for harmony, beating and general weirdness.
analog_backlash
Audio files: 21
PostPosted: Thu Mar 07, 2013 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds perfectly logical (Spock) to me. I must admit, I hadn't noticed the starvation CV control until you pointed it out Rolling Eyes I must pay more attention in future...
Gary
