Transient shaper
Page 1 of 1 [6 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Apr 09, 2005 3:51 am    Post subject: Transient shaper Reply with quote  Mark this post and the followings unread
Ok, I've finally gotten round to doing something with the compressor I was working on. It's a little bit random in the way it works, so play around with the settings until it works for you. This makes programming it suprising sometimes and frustrating other times, but I like the effects you can get from it. It's more of a "transient shaper" than anything else, so it works quite well for tight controlled synth sounds and drums.
I think I prefer this than the G2 compressor for giving a sharp attack transient to sounds, but I'd still use the G2 compressor for keeping levels under control and that sort of thing. It eats up slightly less cycles, but 4 or 5% more memory than the compressor module.
Transient Shaper.pch2
Experimental compressor building block. Useful for shaping the attack transients of synth stabs and drums
 Filename:  Transient Shaper.pch2
 Filesize:  3.18 KB
 Downloaded:  1835 Time(s)
cebec
G2 patch files: 31
PostPosted: Sun Apr 10, 2005 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
this seems undownloadable...
Audio files: 309
PostPosted: Sun Apr 10, 2005 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
At the moment I can't download it either, error 404 it says so maybe the Norway server is down ?
edit : probbably not, other downloads do see to work.
Jan.
PostPosted: Sun Apr 10, 2005 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try to edit the post, kill the attachm,ent and upload it again.
I can see nothing wrong on the server, but I did not find your file. Some demon probably killed the transfer. Shocked Very Happy
Flickr
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Apr 10, 2005 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Attachment fixed. I don't know what happened either Question
Audio files: 309
PostPosted: Sun Apr 10, 2005 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Afrokid.
Nice patch as well !
Jan.
