MFOS SVF Resonance Issue
Page 1 of 1 [6 Posts]
amongstmyselves
PostPosted: Thu Dec 27, 2012 6:41 pm    Post subject: MFOS SVF Resonance Issue
Subject description: Doesn't appear to be working correctly
Hi all,
I've just finished two of the MFOS SVF modules and they both have the same issue / problem.
It appears to be in the Resonance part of the circuit though it's strange that they both have the same issue. I've gone through the board several times and all components are correct. The only changes are small value differences in resistors. Where Ray has 49k9 resistors I have 52k substitutes.
I've attached a MP3 of the audio output which starts with the resonance in the middle (or there abouts) which emulates the resonance pot not being connected. Then I change the frequency cut off which responds as you'd expect but then I turn up the res and it does the weird stuff. The level this puts out is quite high and I needed a pot on the output to stop it clipping my mixer. Sorry no real voltage output measured.
Any thoughts or leads would be appreciated.
PS - If you're interested here's the total synth I am currently building - It's been titled the MFOS - Sound Box Effets 2 - not sure why I went for french naming ? Just did. - http://amongstprojects.blogspot.com.au/
resonance issue - shows issue.mp3
MFOS SVF showing unusual resonance response.
 Filename:  resonance issue - shows issue.mp3
 Filesize:  173.47 KB
 Downloaded:  667 Time(s)
amongstmyselves
PostPosted: Mon Dec 31, 2012 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. I'm intrigued that so many people have looked at this message but nobody has replied. Even with a no idea but ....
Silly question is whether the problem is obvious that it doesn't warrant a reply or whether it really is a new problem ?
PostPosted: Mon Dec 31, 2012 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Filters are hard. Very Happy
amongstmyselves
PostPosted: Mon Dec 31, 2012 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply elmegil. At least people are reading.
It's an odd one as I've mentioned because both boards are doing the same thing. I'll probably go back and go through Ray's troubleshooting guide as a start.
Steve R.
PostPosted: Mon Dec 31, 2012 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
To be more constructive, I'm not entirely sure what I'm hearing there.
Something like starting with a known waveform at a fixed mid-range frequency and then adjusting the filter would be more clear about the problem. What I hear in the MP3 sounds like it's very low frequency to start with.
amongstmyselves
PostPosted: Mon Dec 31, 2012 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok. The audio source into the filter is white noise off the Experimenters board. Firstly I adjust the resonance control which introduces the low frequency osc sound. Then I change the cut off frequency which shows that this function is still working. Then I increase the resonance which sounds like I am applying a square wave lfo. When this sound appears the audio signal level goes off the scale. I have no real way of measuring this level but it is quite high - several volts above the original audio level.
