An Analog Synthesizer for the 21st Century
Page 1 of 1 [3 Posts]
cylon
PostPosted: Thu Jan 31, 2013 6:53 am    Post subject: An Analog Synthesizer for the 21st Century
Subject description: pcb's ??? for Analog Synthesizer for the 21st Century by Thomas Henry
i was wondering if anyone has produced any of these pcb for this synth set of modules i have all the component parts sorted just need some PCB's now.
Many thanks in advance.
Mike
ashleym
PostPosted: Thu Jan 31, 2013 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Try the Thomas Henry sub forum below
or here
http://www.magsmoke.com/magsmoke.asp
Or Fonik makes some of his designs. I havent ready that book so I dont know exactly what the circuits are
PostPosted: Thu Jan 31, 2013 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't believe any of the Fonik TH boards are from Analog Synth... but they are still worthwhile.
I originally started out with the intent of making the whole set from Analog Synth... but then I realized that I could still have a (mostly) TH synth using the boards from Fonik as well as Magic Smoke. I had already bought the hard to find parts, but if you haven't, doing it that way will save you some trouble and expense too.
Note that if you want to set up the patchover scheme from the end, you will need to be able to do inter-module normalling, or you'll need a good sized set of multiples.
