Binary Game Sequencer
Page 1 of 4 [92 Posts]
Goto page: 1, 2, 3, 4 Next
PostPosted: Thu Mar 14, 2013 12:55 am    Post subject: Binary Game Sequencer
Subject description: a divider based CV generator...
hi all,
this is what i finished last night. i am still missing the front panel, so the LEDs are not mounted yet...
it is a new kind of an unipolar sequencer, based on a binary counter/divider (4024), instead of a decade counter/divider (4017).
the concept: each divisions output is routed to an attenuator. the divisions attenuated voltages are then summed.
the realization: each divisions output controlls a CMOS switch. these switches have sockets on it's inputs, normalled to +V. so for each division you could use an external voltage also. this voltage is then going to a simple passive attenuator, and is then routed to one or none of the two CV mixers (on/off/on toggle switch).
additionally each division is converted to a trigger and available at a divider output socket.
a step and reset control makes it complete.
taking a look at the pictures below you see for each division from top to bottom: external voltage input, attenuator, routing switch, LED indicator, division trigger output. bottom row is for I/O (clock, reset, CV outputs A & B).
the nice thing is that you create two CV sequences that are related to each other.
schematics, demo and better pictures will follow as soon as i got the front panel... i just had to share.
[edit: photos replaced]
The Bad Producer
PostPosted: Thu Mar 14, 2013 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Matthias, that's really cool - so if I get this right, you can send each steps voltage to be summed at either A or B or off at the flick of a switch?
PostPosted: Thu Mar 14, 2013 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
correct, however, "stage" might be describe it better than "step".
BTW today i learned that the blacet binary zone follows a similiar concept, but is bi-polar, without the switches, no external voltages inputs, and w/o the /128 division (stage #7).
The Bad Producer
PostPosted: Thu Mar 14, 2013 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I was obviously somewhere else this morning! I get it better now, helped by the panels pic on Muff's, i think I was confused with the binary counting, I went somewhere else, actually seems better now I properly get it Laughing
PostPosted: Fri Mar 15, 2013 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
so here is a 1st sample i did. no big deal, just the Binary game Sequencer, the doepfer quantizer, two thomas henry VCOs (555 and 4046) and my LPG. 1min of patching and it sounds like this:
PostPosted: Fri Mar 15, 2013 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
tony void
PostPosted: Sat Mar 16, 2013 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Listened to this earlier today on my sound cloud subscriptions. Very pleasing to the ears. Had to check this sub forum to what it was all about. Cool idea!
PostPosted: Sun Mar 17, 2013 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice Mathias! Cool
PostPosted: Thu Mar 21, 2013 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
front panel arrived, LEDs mounted, all is working as expected :guinness:
Binary Game Sequencer by fonitronik, on Flickr
PostPosted: Fri Mar 22, 2013 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
:guinness:
Hey Matthias,
I think you'll find that in english it's spelt - genius ! Laughing Cool
PostPosted: Fri Mar 22, 2013 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
fonik wrote:
:guinness:
Hey Matthias,
Shocked
I thought :breakfast: Laughing
PostPosted: Sun Mar 24, 2013 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
PostPosted: Sun Mar 24, 2013 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
last night i made a quick video. no time, no light, bad camera, bad vid quality... anyways, it shows the basic functionality and concept, i think.
quick and dirty demo of my new binary sequencer from fonitronik on Vimeo.
(each CV channel to a X4046 VCO. 1st division trigger out to LPG for 1st VCO, 2nd division out to 12db SVF - in the beginning only channel A, later on channel B fades in. switch set to left routes the CV to channel A, to the right channel B, center position OFF)
PostPosted: Tue Mar 26, 2013 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
and here a few more demos (i am in love with this thing)
Binary Game Sequencer: Another Short Demo from fonitronik on Vimeo.
One more simple Demo of the Binary Game Sequencer from fonitronik on Vimeo.
(using external voltage)
Binary Game Sequencer in Audio Mode from fonitronik on Vimeo.
(in audio mode)
emdot_ambient
PostPosted: Thu Mar 28, 2013 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow...these are crazy good!
LektroiD
PostPosted: Wed Apr 17, 2013 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I hope these will be available as kits in the near future...
LektroiD
Audio files: 161
PostPosted: Mon Apr 29, 2013 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias
i'd be interested in pcb's if you are doing a run.
PostPosted: Mon Apr 29, 2013 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
i will do a run, if there is enough interest.
i already did a re-design of the circuit board to match the eurorack front panel PCB. they could be mounted piggyback to avoid any manual wiring (however, i know that there are not that much eurorack lovers here, no?).
anyways, i will have to finish two other prototypes first (TH ADSR, and the new fonitronik triple vactrol resonator).
BGS_CB
BGS_FP
mcop
PostPosted: Mon Apr 29, 2013 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in a set of boards if you do a run. Particularly interested in it's ability to take external inputs, makes for some very interesting possibilities.
Mongo1
PostPosted: Tue Jun 11, 2013 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I was just watching those videos - this is a really nice design.
I think I could find a place in my system for such a beast if you decide to sell the PCBs.
Gary
PostPosted: Tue Jun 11, 2013 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am really want to. and i decided to do a re-design making it bi-polar, with attenuverters and dgxxx series analog switches. you could then use it i.e. as an 7 channel attenuverting mixer with two summing busses. Twisted Evil
Audio files: 161
PostPosted: Wed Oct 16, 2013 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias
did you have success with the V2 design of this binary sequencer ?
I'am still very interested in this project Smile
I have got a few cd4024's laid aside ready Very Happy
PostPosted: Wed Oct 16, 2013 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
i am working on it, alas, it gives me some headaches, especially the eurorack front panel components PCB - i think i will still use ribbon cables for the interconnections...
anyways, the schematic is done, and the circuit board is done. the new features are:
bi-polar with attenuverters
a rotary encoder ISO a step switch: this way one can 'scroll' trough the steps. should be much faster than a step switch, all the more if you go through 128 steps to have all channles on for a 7 channel attenuverting mixer.
mcop
PostPosted: Wed Oct 16, 2013 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to see this is still going. Been looking forward to this and was wondering how it was progressing.
Audio files: 161
PostPosted: Thu Oct 17, 2013 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great , a probable xmas project ,i look forward to it Smile
