eXisteNz
Posted: Thu Mar 21, 2013 6:30 pm Post subject:
0,1 % resistors |
Hello!
i'm approaching to build pcbs, i wonder which malfunction might arise if i put 1% in place of 0,1% resistors? and....i have not a fluke for hand match resistor, but a DMM...i read about wheatstone bridge technique for selecting 0,1 values.... anyone know well this procedure?
cheers
Nico |
Joined: Apr 03, 2004 Posts: 24626 Location: The Netherlands, Enschede
Audio files: 317
Posted: Thu Mar 21, 2013 7:14 pm Post subject:
Your range or tuning may be off with 1% when 0.1% was specified - when nothing was specified usually 5% is assumed and 1% will be fine, or overkill - depending on pint of view. 0.1% is rare really.
Fluke is just a brand for DMMs, so that's fine prolly.
Re. Wheatstone, yes I know all the details please zoom in a bit, maybe point to a website you saw and have questions about? _________________ Jan
Posted: Thu Mar 21, 2013 10:35 pm Post subject:
From what I remember,
The .1% resistors (i think only about 10 or so are specified as such) just need to be within .1% of each other. They are for gain matching the op-amp stages. They don't have to be spot on the value, just the same as each other.
So,...buy about 100 or so 1% metal film resistors of the value quoted (eg 100K), and, using your DMM, sort them into piles which are matched to .1% (ie 99.8, 99.9, 100, 100.1, 100.2, etc. When one of the piles reaches the number you need, that's the pile you use. _________________ What makes a space ours, is what we put there, and what we do there. |
eXisteNz
Posted: Fri Mar 22, 2013 4:36 am Post subject:
Yes i understand, but i can't match them each other because my DMM on 100k range have an accuracy of 1ohm only (i.e it can read only 99kohm 100kohm 101kohm; and not 99,1 99,2)....
As regarding W.Bridge.. if i need to match each other only, i don't need to put a potentiometer, but only 3 resistor of known 0.1 accuracy value.... is that right?
I found these resistors, and i wonder if you could identificate as precision one since i dont' know which kind are these on the photo i'm attaching, i have 7 of 10k and 8 of 100k...
Then other question is: can i use 3 resistors of the same values on the bridge? i.e. can i use my 3 100k green precision resistors (if they are) as R1, R2, R3 for match the other 1%metalfilm 100k (Rx)?
And lastly: then i measure voltage between points that aren't connected at 9v battery voltage source is that right?
Well i think that answering these questions could be a good starting point to study calculus to do next...
Sorry for my poor english and thank you sooooo much for your patience!
nico
52.08 KB |
| Viewed: |
699 Time(s) |
Posted: Fri Mar 22, 2013 5:41 am Post subject:
For a Wheatstone if all you're doing is matching *to each other* don't you only need two super-accurate resistors for the top half of the bridge?
Having the third is so you can be certain that all your matches match that third one, as I understand it.... ??
I have doubt because I haven't done this.... |
Posted: Fri Mar 22, 2013 7:49 am Post subject:
So I did some more searching and this seems like a fairly definitive source:
http://www.muffwiggler.com/forum/topic-61933.html
one question I have though is....would it be possible for your initial go round to do something more like this to get started:
take the top two resistors, put them on either side of a high quality trimmer, put a voltage across the whole thing and then adjust the trimmer to as close to exactly 50% of the voltage as you can manage. This gives you a solid starting point, probably better than starting with two random 1% resistors.
build the rest of the bridge, put a trimmer at the bottom as well. Run your source voltage across the wipers of the two trimmers, and adjust the lower one until you get a balanced bridge (the other measurement is 0).
Then swap out one of the lower legs repeatedly, noting the difference measurement, and sorting by that measurement, with the idea that any that are at the same difference value must be high degree matches.
For future use, take three that you match this way and omit the trimmers.
I doubt that's simpler or faster than Ian's method (probably not, I don't think I would dare to compare my lack of experience with his years doing this stuff), but it had occurred to me before reading the Muff's article and I wanted to ask if I'm being logical here. |
eXisteNz
Posted: Fri Mar 22, 2013 8:24 am Post subject:
thanks elmegil for your ideas and link, i'll definately try them, i really don't know if it's works because i know far less than you about this technique....
COuld you please try to identificate which type of resistor is the one i've attached above in the photo? Since i have a 7-8 100k like that, i was wondering if they're precision military grade resistors....
thank you! |
Posted: Fri Mar 22, 2013 8:45 am Post subject:
| Unfortunately I've never seen that kind of resistor before.... |
capicoso
Posted: Wed Mar 27, 2013 10:10 am Post subject:
| eXisteNz wrote: | Yes i understand, but i can't match them each other because my DMM on 100k range have an accuracy of 1ohm only (i.e it can read only 99kohm 100kohm 101kohm; and not 99,1 99,2)....
That's weird, is it an old one or something? Even my 5usd cheapest DMM can read 100,1 99,9 |
eXisteNz
Posted: Thu Mar 28, 2013 1:25 am Post subject:
Well it's a weird cheap new Tenma DMM model 72-7925:
RANGE RESOLUTION ACCURACY
200R 0.1R +-(0.8%+3)
2K 1R +-(0.8%+1)
20K 10R "
2M 1K "
20M 10K +-(1%+2)
DISPLAY MAX: 1999
So to measure 100k i have to go in 2M range having only 1k of resolution
Anyway i've hand selected them with weathstone bridge and all was ok..
After a day i've remeasure with this DMM to see if at least all 25 resistors measure the same: 21 of them measure steady 98 but there's 4 measuring 99!!!
At the end now i'm ordering 25 100k 0.1% resistor from my supplier!
Definately i have to buy a new DMM! |
