syntherjack
Joined: Oct 29, 2012 Posts: 21 Location: Poland, Poznan
Posted: Mon Apr 15, 2013 12:39 pm Post subject:
Euro modular power supply project [COMPELETE PCB+SCHEME] Subject description: Everything you need to build your reliable modular synthesizer PSU. |
Hello,
I'm working on my big and fat modular drum synth. As first, I completed PSU - it is designed for euro standard (+/- 12V). Below you can find:
- full schematics,
- PCB for easy DIY cloning,
- BOM,
- some pictures.
PSU in based on Doepfers Modular PSU, but has few little upgrades:
- it uses more popular, cheap heat-sinks,
- better quality capacitors,
- protection diodes,
- changed connector spacing for easy operation,
- 2x1,5A output @ 12V (tested).
The PCB is 160x100mm (standard EURO card), one sided.
Total cost cost about 25 euro (when you do PCB on your own).
Happy DIYing!
| Description: |
| Completed PSU, output connectors. |
| Filesize: |
1.86 MB |
| Viewed: |
256 Time(s) |
| Description: |
| Filesize: |
1.74 MB |
| Viewed: |
289 Time(s) |
| Description: |
| Filesize: |
50.69 KB |
| Viewed: |
445 Time(s) |
| Description: |
| PSU, bottom PCB side with components. |
| Filesize: |
180.83 KB |
| Viewed: |
297 Time(s) |
| Description: |
| PCB ready to print, parts layout and BOM. |
 Download (listen) |
| Filename: |
PSU_euro_complete.zip |
| Filesize: |
85.3 KB |
| Downloaded: |
330 Time(s) |
roglok
Posted: Mon Apr 15, 2013 2:45 pm Post subject:
| Wow, looks great. Thanks for posting! |
Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Mon Apr 15, 2013 11:47 pm Post subject:
That is a seriously neat design - Thanks, very useful  |
roglok
Posted: Mon Apr 15, 2013 11:52 pm Post subject:
| One question though: Is there any specific reason for the tantalum caps? Are they just for decoupling the LEDs? I'd like to avoid tantalum because apparently they tend to short circuit in some cases. |
syntherjack
Posted: Tue Apr 16, 2013 11:46 am Post subject:
| The main reason to use tantalum caps is LM317 datasheet, they're recommeded. Those caps tend to short circuit when thermal and voltage limits are exceeded. I used 25V, 85C caps, so there shouldn't be a problem. If you have bad experiences with tantalum, you can always 100uF parallel with 100nF. |
risingson
Posted: Tue Apr 16, 2013 12:53 pm Post subject:
| Thanks for this! Would you consider open-sourcing schematics and layout files? It would be easier for me to get a few fabricated then to etch myself. |
01012k7
syntherjack
Posted: Sun Sep 01, 2013 2:50 am Post subject:
Nice job!
I hope it will work fine for long years! |
01012k7
