HyperSquare
Page 1 of 1 [7 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Mar 30, 2005 2:14 am    Post subject: HyperSquare Reply with quote  Mark this post and the followings unread
Another in the Hyper series, this time square, for all those not making trance music Embarassed . Not so many oscillators as the hyper saw because I find there are diminishing returns for adding extra oscillators. Two is much fatter than one, three is fatter than two, four is a little bit fatter than 3 etc, etc.
Other enhancements are a chained gain system for the extra oscillators which adjusts from all 100% to only the primary, mid settings have the more detuned oscillators tapered off.
Also a 4 phase PWM lfo. This is not based on any other synth module or VA, just an idea. Variation two uses the wheel to morph from a single square to near maximum everything. Only 4 variations, the rest is a common VCF/2ADSR/VCA so you can create your own variations.
HyperSquare.pch2
unison square plus
 Filename:  HyperSquare.pch2
 Filesize:  2.71 KB
 Downloaded:  1830 Time(s)
Audio files: 228
PostPosted: Wed Mar 30, 2005 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I remember a beast called a PolyMoog in 70s. I made sounds similar to this.
cebec
G2 patch files: 31
PostPosted: Thu Mar 31, 2005 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
really cool. i had some nice soundtracky pads going in no time.
Cool
3phase
G2 patch files: 141
PostPosted: Mon Apr 25, 2005 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
wow...what a beauty... in red it could be the nordmodular stage version Smile
G2egory
PostPosted: Mon Apr 25, 2005 7:20 pm    Post subject: Re: HyperSquare Reply with quote  Mark this post and the followings unread
I agree. This is a great classical sounding synth patch, very analog-like. Thanks for sharing it.
Gregory
P.S. The picture of the old Moog sure looks good.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Apr 25, 2005 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
moog add wrote:
At any time, the pre-programmed voices can be altered with the variable controls, allowing limitless creating of new sounds.
LOL! The Polymoog had about two good sounds, it’s only relative in synthesiser history is the Korg PS series. Both had the hybrid organ, synthesiser on a chip type architecture. Korg did a much better job though, the Polymoog’s on chip filter was so lame that they put in a global (only one) moog ladder filter which made it play like an ARP omni.
I think this keyboard may have played a big part in the demise of Moog Music.
Audio files: 228
PostPosted: Mon Apr 25, 2005 9:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha ha, you are probably right. It was a turkey. I didn't want to come out and say that because I said it sounded like your patch. Laughing
