13th Januar - is so called Russian Old New Year Celebration!
Page 1 of 1 [16 Posts]
Ganzha
Audio files: 27
PostPosted: Sun Jan 05, 2014 4:28 am    Post subject: 13th Januar - is so called Russian Old New Year Celebration! Reply with quote  Mark this post and the followings unread
Hello!
Last 2013 Year i was in live in internet radio electro-music.com in so called Russian Old New Year Celebration.
I would like to repead this eent - i am going to play ones more in 13 Januar at 2014.
I have question - is it possible?
.jpg
 Filesize:  78.24 KB
 Viewed:  28375 Time(s)
.jpg
http://ziart.kz
PostPosted: Sun Jan 05, 2014 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ganzha,
Januari 13 is a Monday. Every Monday from GMT 22:00 till GMT 24:00 Paul has a show.
All other times on that day are still free to my knowledge, so yes that would be possible.
Please give us a GMT time, a duration and a name for your event.
You will also need someone to be around to be able to switch you in, so I would suggest you do something just before Paul's show - biggest chance then that there will be a stream operator around.
Ganzha
Audio files: 27
PostPosted: Sun Jan 05, 2014 1:10 pm    Post subject: time is 00-00 when 13 dec start to be 14 Reply with quote  Mark this post and the followings unread
I am in -6 from GMT it means - 00-00 will be here (Central Asia) at 18-00 - at GMT - 00-00 (London)
What do you think?
Honesty speaks - 18-00 by GMT in Monday is not good for radio - the better would be 21-00 by GMT ( 3-00 Central Asia 14 Jan)
http://ziart.kz
PostPosted: Sun Jan 05, 2014 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think I act, I am a politician Shocked
Laughing
Anyways ... 18:00 GMT is a bit early for the radio .. I think so too ...and also there may not be switchers around at that time, although we could try get a volunteer of course.
Would 21:00 GMT be too late for you? Otherwise that would be best I think.
Damn .. I did it .. I had THINK Confused
Ganzha
Audio files: 27
PostPosted: Sun Jan 05, 2014 9:01 pm    Post subject: 21 GMT is good for me ! Reply with quote  Mark this post and the followings unread
That would be good for me 21 GMT is 3-00 jan 14!
it is ok!
http://ziart.kz
PostPosted: Tue Jan 07, 2014 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok ... have a look at http://www.electro-music.com/~janpunter/view_schedule.php please, is that all OK for you?
Audio files: 235
PostPosted: Tue Jan 07, 2014 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great! Looking forward to it. Or, maybe I should say hearing forward to it. Shocked
Ganzha
Audio files: 27
PostPosted: Wed Jan 08, 2014 1:24 pm    Post subject: Ok! Great!!!!! Reply with quote  Mark this post and the followings unread
Great!!!!!
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Sat Jan 11, 2014 5:47 am    Post subject: Direct Lathe mastering Reply with quote  Mark this post and the followings unread
during my on-line internet streaming in 13 - 14 Jan via radio-electro-musiccom would be direct mastering by Lathe recorder
In russian
Во время он лайн трансляции новогоднего концерта 13-14 Янвая будет осуществяться прямая запись механическая запись на только что пришедшую установку
 Filesize:  116.29 KB
 Viewed:  1002 Time(s)
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Sat Jan 11, 2014 6:20 am    Post subject: Driver Amp are 2 LOMO Russian intage 100watt apms Reply with quote  Mark this post and the followings unread
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Mon Jan 13, 2014 3:23 pm    Post subject: set had been recorder Reply with quote  Mark this post and the followings unread
Set had been recorded!!!!
http://ziart.kz
PostPosted: Mon Jan 13, 2014 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Set was nice :-)
Ganzha
Audio files: 27
PostPosted: Mon Jan 13, 2014 4:02 pm    Post subject: Thanks!!!! Reply with quote  Mark this post and the followings unread
sorry for unexpectale crashing at start it spoiled some minutes form ear time!
If someone recorded set - please post it here,
I would be able to post it tomorrow only!
 Filesize:  631.67 KB
 Viewed:  27725 Time(s)
part01_old_2014.mp3
 Filename:  part01_old_2014.mp3
 Filesize:  18.31 MB
 Downloaded:  2016 Time(s)
part02_old_2014.mp3
 Filename:  part02_old_2014.mp3
 Filesize:  26.19 MB
 Downloaded:  2058 Time(s)
part03_old_2014.mp3
 Filename:  part03_old_2014.mp3
 Filesize:  32.9 MB
 Downloaded:  2073 Time(s)
part_04_old_2014.mp3
 Filename:  part_04_old_2014.mp3
 Filesize:  23.09 MB
 Downloaded:  2003 Time(s)
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Tue Jan 14, 2014 5:52 pm    Post subject: Music video part 01 Reply with quote  Mark this post and the followings unread
here is music video of part 1
http://youtu.be/nF8naHFNeHM
https://vimeo.com/84178024
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Wed Jan 15, 2014 11:25 am    Post subject: there is part 2 Reply with quote  Mark this post and the followings unread
there are
http://youtu.be/rgb2rex_6cs
http://ziart.kz
Ganzha
Audio files: 27
PostPosted: Fri Jan 17, 2014 7:32 pm    Post subject: there is video part 3 Reply with quote  Mark this post and the followings unread
there is
in vimeo
https://vimeo.com/84260052
http://ziart.kz
