Tim Kleinert
G2 patch files: 236
Joined: Apr 03, 2004 Posts: 24505 Location: The Netherlands, Enschede
Posted: Sun Jan 26, 2014 5:55 pm Post subject:
I think 699 s is a bit short at times .. 371 years would be too much for most practical purposes ... but lets say one hour or a day maybe and then with some different wave forms .. i could actually use that I guess.
Had a quick look at the patch .. could use a couple of lines of how it works ... and how I could change the speed.
In the past I've used another way to make things slow BTW ... using a delay controlled with a saw .. that is .. downsampling an LFO.
For random I'd now use a sample and hold I guess .. but would be nice then if the smoothing could be set to be really long too ...
Anyways .. just some babblings
6 point how many billion years you're nuts I'd like to see that one too tho ... but again .. with a couple of comment lines please. _________________ Jan
Tim Kleinert
G2 patch files: 236
Posted: Mon Jan 27, 2014 6:13 am Post subject:
It was just a little thought experiment using two nested counter circuits counting the smallest possible increment within the 24 bit numerical system @24kHz. Counting to 2^48 at 24000 times a second takes 371 years. The 6 billion version would simply add another counter stage. (2^72)
I'll have to (happily) eat my words though pertaining the G2 LFOs, because some further testing revealed that their internal counters DO in fact seem to have an even higher resolution than 24 bit after all. Meaning: If you simply apply a negative constant to the LFO mod input, it goes even slower than the slowest base setting of 669 seconds.
The mod inputs can take a maximum of +/- 64 units and track exponentially (unattenuated). So, if the math still is correct at these low rates, a -12 constant (12 semitones or an octave lower) should drop the LFO frequency by half, -24 by four, etc. -60 (5 octaves, or factor 32) should give you 5.94 hours, and -64 even more than that.
I haven't measured it precisely (*), but it's definitely running waaay slower. Try it.
Come to think of it, in this case one could patch the 6 billion years LFO simply with two LFO modules (using the concept of interference and modulating the phase of one with the other).
(*) EDIT: I tested it and it is robust. The test patch below demonstrates a sawtooth LFO at 669 seconds and another one tuned down 5 octaves and its range boosted by factor 32 -both modulating test oscillators panned L and R. The pitches match up perfectly. Well done, Clavia.
| Testing the tracking of LFOs at slowest rates. See topic for discussion. |
 Download (listen) |
| Filename: |
slow LFO test.pch2 |
1.3 KB |
| Downloaded: |
4350 Time(s) |
Tim Kleinert
G2 patch files: 236
Electromagnetic Wave
G2 patch files: 38
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Thu Jan 30, 2014 10:00 am Post subject:
Great! I'm going to start testing it. Excuse me if I die before showing any results!  _________________ Cheers,
Albert |
Tim Kleinert
G2 patch files: 236
Posted: Thu Jan 30, 2014 5:37 pm Post subject:
| Electromagnetic Wave wrote: |
Is it true for Osc modules too ? I mean can I get better resolution than 0.0057 Hz ? Or I mix apples with oranges ?! |
I don't know. There are at least two potential bottlenecks here. The resolution of the counter is one thing, but the other is the lin-expo conversion math for the incremental value. The upward detune factor of a given frequency for one cent is the 1200th root of 2. Resolution issues therefore ,logically, are bigger at low frequencies.
What I do know for sure is that the oscillators will, with correct settings, accurately track the keyboard, even in the sub-audio range. This discovery made it possible for me to optimize my granular synthesis algorithms, and thus throw in more features (individual multimode filter per grain). So I guess the oscillators, too, have pretty good resolution.
| Quote: | | I played a bit with the speed in the "371_years_lfo" patch. |
Cool. It's just a counter circuit, easy to speed up. We'd better, otherwise Albert (dorremifasol) is gonna die before showing any results.  |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Fri Jan 31, 2014 3:30 am Post subject:
drapdap
Posted: Sat Feb 15, 2014 11:59 am Post subject:
nice patch... mp3 demo?
can you estimate the lifetime of a g2?  |
