Could I have some advice on my patch please..
Page 1 of 1 [7 Posts]
wheely
PostPosted: Wed Mar 12, 2014 12:28 pm    Post subject: Could I have some advice on my patch please.. Reply with quote  Mark this post and the followings unread
Hey guys, howsit going.
Ive not great at this, but ive made a patch, that has my Tempest drum machine come into channels 1-2. Ive taken a split of the input straight, and have a dy unaffected signal on a mixer channel, plus the eFXed channels on the mixer, so i have wet/dry. These also a channel for another mono synth input (channel 3) and a Ableton return (channel 4 mono)
Im really just interested in the drums.
The fx are in stereo, distortion, saturation, phaser, delay, vowel filter, comp, gate and reverb is down on the fx section.
G2 is synced to tempest, and id like to automated some of the fx in time. Not sure how to do this the most effectively.
Has anyone got some cool tricks for effects on drums they could share with me, or could someone look at my patch and maybe tweak it?
thanks.
W:
Audio files: 309
PostPosted: Fri Mar 14, 2014 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
What patch? Did you intend to attach it?
wheely
PostPosted: Fri Mar 14, 2014 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, no i didnt, just wanted to see if anyone would take a look first.
wheely
PostPosted: Fri Mar 14, 2014 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
heres the patch
DRUMM THRU V2.pch2
 Filename:  DRUMM THRU V2.pch2
 Filesize:  3.49 KB
 Downloaded:  4095 Time(s)
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Mar 15, 2014 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Something like this ? Look into the fx section. You can select from a sequencer or a lfo to automate the Reverb module parameter (Dry/Wet).
EDIT : be sure to load in slot A
drumm_thru_v2_139_testReverb11.pch2
 Filename:  drumm_thru_v2_139_testReverb11.pch2
 Filesize:  4.16 KB
 Downloaded:  4249 Time(s)
wheely
PostPosted: Sat Mar 15, 2014 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
cool thanks!
But how are you telling the automation to go to that reverb, and not something else?
Can I automate any parameter like that, if so, how ?
wheely
PostPosted: Sat Mar 15, 2014 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I get it now, by assigning them midi ctrl numbers.
thanks!
