Joined: Dec 11, 2010 Posts: 1029 Location: Toronto, Ontario - Canada
Posted: Sun Mar 30, 2014 9:19 am Post subject:
Cynosure's Requests and Bugs |
Here is a list of things that I came up with. I will add more as I think of them.
SUGGESTIONS
-Module: MixM4to1, MixS4to1
Request: Mute button for each channel.
-Module: New - Clock
Request: Clock module with scale in BPM and both trigger and gate outputs. Gate has control for length.
-Module: New - 24dB Filter
Request: Similar in function and control to SVF, but as a 24dB lowpass filter.
-Functionality: Zoom
Request: Ability to zoom in or out. Would make editing easier (the controls and modules are tiny).
-Functionality: Master Reset
Request: A button to reset all clocks, VCOs, LFOs, sequencer, dividers and logic. Sometimes stuff gets out of sync while plugging and adjust and there is no easy way to get them all back in sync.
-Functionality: Remember Window Setting
Request: Application defaults to the last used screen setting (maximized/windowed). Currently it always starts windowed. If only one option can be used, then I prefer maximized.
BUGS
-LED Freeze
Bug: Timing LED indicators freeze when a new module is added.
Replicate: Drag a new module into the workspace while the program is running.
Ideal: LEDs continue to blink.
-Save As Full Directory
Bug: The full file directory is displayed as the file name when using the Save As option.
Replicate: Select Save As for a patch that has already been saved.
Ideal: Only the file name is used as the default value. |
Posted: Sun Mar 30, 2014 10:05 am Post subject:
Thanks! Will look at it. _________________ Jan
Posted: Sun Mar 30, 2014 5:08 pm Post subject:
For now:
Added mutes, a reset button and memory for window state, this will be in the next release.
Zoom will not happen, the user interface is not scalable, it would need all bitmaps to be replaced with vector graphics. And that would need support for vector graphics too .. this is not a native image format in Delphi.
LED freeze is a known issue ... not sure why that happens .. a simple module move seems to cure it  _________________ Jan
