Shasta321
Posted: Mon Apr 28, 2014 12:33 pm Post subject:
New to Music Production (Need help) Subject description: I'm new to music production, and i need some help. |
| Hi, i'm new to Music Production, and i have no idea where to start. I was wondering if anyone could point me to good tutorials, and other helpful things that will help me learn to create music. I use FL Studio 11, and i want to create Electronic music and other music in that area. |
Joined: Jan 31, 2003 Posts: 18316 Location: Durham, NC
Audio files: 235
Posted: Mon Apr 28, 2014 1:03 pm Post subject:
to electro-music.com
I know some really great musicians that use FL, so you are off to a good start. I don't know that program myself.
This site seems to have a lot of FL based tutorials, and there are many more sites.
http://howtomakeelectronicmusic.com/tag/fl-studio-tutorial
Unless you find a local teacher, just start making as many tracks as you can. Try to avoid being too self-critical. It's a long road, but after a while, you'll find some direction.
BTW, as admin, I'm moving your post to the Introduce Yourself sub-forum. _________________ --Howard
my music and other stuff |
Shasta321
Posted: Mon Apr 28, 2014 1:18 pm Post subject:
Thanks |
| Thank you for giving me some advice, it's kind of hard going blindly into this. How would you suggest I start making music? What way did you start off, and how did you learn to make full songs that have a good sound? Also, would you say that i need a lot of Music Theory knowledge? Once again, thanks. |
Audio files: 235
Posted: Mon Apr 28, 2014 1:35 pm Post subject:
I had a great teacher, and got a couple of music degrees. I don't think that is necessary to make music though. It certainly won't help you make a living.
Before the formal instruction, used short wave radios because there were no synths one could buy. I would tune into the static between stations and record those sounds while I adjusted the radio's knobs. I had a stereo tape recorder and would record two tracks and then mix them onto another tape recorder. This made what one would call "abstract" electronic music, which is what I was interested in at at that time. '
That method worked for me at the time. You have to discover some method of your own.
You can post your attempts here on the forum by using the attachment mechanism.
I suggest very strongly that you spend a lot of time listening to the music posted here on the forum, as well as on other sites. That will give you ideas.
Don't try for long pieces at first. Make short 2 or 3 minutes tracks, and make a lot of them.
Most important, have fun!!
Right now, tune into radio.electro-music.com for Edison's Electronic Review, (starts at 5 PM EDT), and join the chat room. It's easier to make this journey with friends. _________________ --Howard
Shasta321
Posted: Mon Apr 28, 2014 1:42 pm Post subject:
Thanks |
Thank you again for helping me, and thank you for sharing your introduction into music with me. I am very into Artists like Madeon, if you have heard of him. It's a very French Electro type of music, so i'll look out for things on that.  |
Audio files: 235
Posted: Wed May 07, 2014 1:44 pm Post subject:
Thanks for the heads up about Madeon; I had never heard of him. I see why you are impressed.
So that is French electro. Occasionally I get some bad mouthing that electro-music.com isn't about electro. Maybe that's true, but electro-music isn't necessarily associated with any genre.
Nevertheless, good luck on you journey. _________________ --Howard
Nickson
Posted: Sat May 17, 2014 10:59 am Post subject:
Welcome Shashta321,
I'm using FL studio as well, maybe I could help you out for a bit.
I've recently made a topic with a song that I made using FL studio, you could check it out to see what type of music I make.
Have fun here! |
mattgreermusic
Joined: Jul 25, 2014 Posts: 11 Location: Nashville, TN
Posted: Fri Jul 25, 2014 12:57 pm Post subject:
an idea |
As someone who is new to this, you might want to try just emulating some of your favorite songs at first. This might not seem that creative but think of it more as an exercise.
Basically, find a tune you like and just focus on deconstructing and then rebuilding the various elements. What's the kick doing? Identify the pattern and approximate tempo and make your own version of it. This is very easy to do in the pattern step sequencing type interface that FL offers. Just back and forth between your reference track and your own music until it sounds basically the same. Okay, so the kick is right? Move on to the snare, then the hi-hat and so on. Just rebuild the song basically. Once you understand how to program the patterns, you'll have an idea on how to start building a song. From there you can tweak it a little. Change the kick pattern. Slow the tempo. It will start to turn into something of your own. Do one every day (or as often as you can). Keep at it and you will become better and better.
Good luck. Welcome to the addiction. |
