today> Twyndyllyngs - canceled because of back pain - sorry Chez Mosc
How to trigger Dumping of Program parameters via CC/Sysex
Page 1 of 1 [11 Posts]
syrious
PostPosted: Sun Jul 06, 2014 3:08 pm    Post subject: How to trigger Dumping of Program parameters via CC/Sysex Reply with quote  Mark this post and the followings unread
Hello there,
I'm looking for a possibility to tell the Nord Lead 4 to send me all parameter values via Midi CC.
Manually, thats possible in the MIDI menu / 6 - Send CC (page 43 in the manual).
Exactly that I need to trigger with a midi cc or if necessary with a sysex message.
How (which midi cc / sysex message) to achieve that?
Is there documentation I missed?
Audio files: 500
PostPosted: Tue Jul 08, 2014 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, I am sure the NL4 should be able to do this, but after a quick scan of the manual it seems there is no sysex info there…
You can do a Dump One command from the front panel of course… (also page 43)
syrious
PostPosted: Thu Jul 10, 2014 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
however I exactly need to trigger the param transfer in the opposite direction, that is: VST->NordLead
Any ideas / suggestions how to achieve that?
Audio files: 500
PostPosted: Thu Jul 10, 2014 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, as I said, there is nothing in the manual about system exclusive messaging, which seems like an oversight to me... The NL4 certainly accepts sysex.
What you are looking for is an All Controllers Request message, which previous Nord Leads would accept. Either that or a Patch Dump Request.
Maybe time to ask on the Nord Forum perhaps, or Clavia support even.
Sorry I can't help you more, any searches I did turned up blank.
syrious
PostPosted: Fri Jul 11, 2014 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the answer.
I still posted in the nord forum where I got no reply and asked Nord Support who couldn't or didn't really want to help me. I also googled for some hours.
At least now you gave me two key words for which I will try to find a sysex message that I can send to the nord lead.
Audio files: 500
PostPosted: Fri Jul 11, 2014 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, this is a shot in the dark, but have you tried this?
Byte (Hex)
$F0 $33 $00 $04 $14 $00 $F7
Byte (Decimal)
240 51 0 4 20 0 247
This is the All Ctrl Request message for both the Nord Lead 1 and 2X, so they may have kept it the same. For this specific message the global channel must be 1 and it sends the controllers for Slot A. The global channel (device ID) is the third byte, if you want to change that.
syrious
PostPosted: Sun Jul 13, 2014 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply..sounds promising..In the first try my sysex I sent didn't affect the nord lead.
I asked for help / example code in another forum as there is no documentation for the framework I'm using to build the VST.
EDIT: Today I got reply from Nord that the "Request All Controllers" command is not available in the Nord Lead 4. So that's it with my project Sad
Btw. thanks Muied Lumens for helping
syrious
PostPosted: Fri Jul 25, 2014 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
It turned out that sysex can not be send from my targeted daw (ableton live).
So sysex is no more an option for my problem.
Thread may be closed.
Audio files: 500
PostPosted: Fri Jul 25, 2014 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
EDIT: Today I got reply from Nord that the "Request All Controllers" command is not available in the Nord Lead 4. So that's it with my project.
What a pity! Perhaps Clavia will include sysex capability in a future update... seems strange not to.
Also, maybe with Max for Live it is possible to do sysex? I don't know Live at all though.
syrious
PostPosted: Mon Jul 18, 2016 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Eventually I gave up...enough hours burned for nothing...sold the synth
Audio files: 500
PostPosted: Sat Jul 23, 2016 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Heh... and I bought one. I had forgotten about this thread, still think it is strange that there is no sysex, have to double check that.
Nothing is for nothing though. Working on problems is never a waste of time, even if you never found a solution. IMO of course.
