today> Twyndyllyngs Chez Mosc
PCB offer: Thomas Henry's Controller LFO
Page 4 of 4 [80 Posts]
syrinx
PostPosted: Thu May 29, 2014 10:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks, just wondering if anyone can tell me how much power these things consume. I'm running into some limits in my current power system and trying to plan an upgrade, but I have lots of DIY modules and am finding it difficult to track down power consumption specs. Thanks!
gribus
PostPosted: Wed Jul 16, 2014 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
any news on equivalents for the 2N5461 ?
have some 2N5460 , but they are built for lower voltage , ?
robboten
PostPosted: Tue Jul 22, 2014 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Have just assembled mine. Was out of trimpots so had to use a couple of 50k instead of 25k at sine round and instead of 100k at amplitude. Otherwise I've done as stated in THs files. It works good except that the contr. out is extremly high, about 20Vpp with trimpot at lowest setting. When turning pot the other way it's actually clipping. Have looked at resistors around output and they all are correct. I don't really know if the 50k trimpots are at fault or anything else. Does anyone know where to start looking? Don't want to burn my other modules with too high Voltages.¨
Also: What spacers are used in this and the 555VCO?
tkm
PostPosted: Mon Oct 06, 2014 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please tell me that these boards are still available?
i need pcbs..
PostPosted: Wed Feb 27, 2019 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
The 2N5461 N-channel is obsolete today.
But one could use the J175, however, it has a different footprint which makes the mounting a little bit fiddly.
here is a picture that shows the different pin-out and how it corresponds to the PCB:
