AY-Voice is Underway
Page 7 of 7 [154 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7
theshaggyfreak
PostPosted: Mon Jul 21, 2014 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
elmegil wrote:
Nope....
Though I understand that if you use a different type of microcontroller, the latency issues can be overcome.... But you'd be working all that out for yourself (or at the very least, starting a project of your own somewhere under DIY rather than here).
Ahh. I'll just have to keep my eye out for some other projects. I don't really have any understand of microcontrollers in a way where I could work it out on my own.
Shaggy
http://www.pureshift.com
http://www.bsodmusic.com
PostPosted: Mon Jul 21, 2014 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
No time like the present to start and learn Smile
Thomas_Henry
PostPosted: Mon Jul 21, 2014 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
At lot has happened between then and now, two things in particular. First, a couple years ago I chucked Picaxe altogether and now work strictly with the PIC. And then I got waylaid with all sorts of other projects--you wouldn't believe my to-do pile that I'm slowly working through, even though in my dotage I now can devote twelve hours a day to electronics.
Anyway, I do expect to get back to this project one day. It actually would be pretty straightforward to port the Picaxe code over to compiled Great Cow Basic.
The one thing, though, I still think the internal EG stinks, so will probably go with a better external one.
TH
theshaggyfreak
PostPosted: Tue Jul 22, 2014 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I wish! Unfortunately, I only have a limited amount of time that I can work on my projects and I have very little (almost none) knowledge of programming in general. I'm mostly working with 555 circuits these days as far as design goes. I'll just keep these Ay3 chips in my drawer for now. Hell, I still have an SN-voice to build! I have one of the original run PCBs that I need to get working! So many projects...not enough time. Smile
Shaggy
