pmpv
Posted: Tue Jul 22, 2014 4:32 pm Post subject:
Nord Rack 2X Pitch Bend error |
Hi!, i have the nord rack 2x, lately when i turn on the synth a randomly ''pitch bend error'' message started to appear and now, whenever i turn it on i'm always getting that error message.
Can anyone help me?
Slot A is set to Midi Chanel 1
Slot B is set to Midi Chanel 2
Slot C is set to Midi Chanel 3
Slot D is set to Midi Chanel 4
Global Chanel is set to 5.
These three parameters are on: P.on, C.on, A.on.
I'm using Roland XP-10 to control nord rack 2x
How can i get rid of this error, fix pitch bend and modulation?
Thanks.  |
Joined: Apr 03, 2004 Posts: 24617 Location: The Netherlands, Enschede
Audio files: 316
Posted: Tue Jul 22, 2014 5:30 pm Post subject:
hi pmpv -
I'm a noob too but sounds like a hardware issue to me, with the pitch stick ... it may just be a loose cable, but the Clavia pitch sticks break on occasion, you can probably get a new one through the local distributer. It should not be too hard to fix it that way. _________________ Jan
pmpv
Posted: Tue Jul 22, 2014 5:34 pm Post subject:
Hey ! Thanks !
I brought it on second hand and i can't give it back, but as a rack version it doesn't have the pitch bend, so i dont understand the issue. |
Audio files: 316
Posted: Wed Jul 23, 2014 2:21 am Post subject:
Ah ok .. should have seen that ...
for the nord modular I know it does a startup scan of its hardware and with loose cables it can give that error too, even when it is a rack ... I'd open it up and try to pull the cables and plug them in again. _________________ Jan
pmpv
Posted: Wed Jul 23, 2014 3:13 am Post subject:
| Thanks for response, i'll see if i can manage that. |
pmpv
Posted: Wed Jul 23, 2014 5:26 am Post subject:
Hum, a strange thing happened.
Everything works now when i had a midi -> USB interface connected to Midi Thru on Roland XP10. When i disconnected that the nord rack started normaly.
It shows 1.00 (might be software version dunno) then nL2, then the preset and it's ready to use, is this normal right?
But going back to the strange thing that was, the Roland XP10 was turned off, would really that midi interface connected to midi thru was causing this pitch bend error? Because there were no electric current on the roland, i just turned on the rack alone.
After disconecting that midi interface ( this one http://windowsphonesupport.com/blog/wp-content/uploads/2012/09/USB-Midi-Cable.jpg ) i turned the nord rack on alone by 20 times over 20 minutes of use and since then i didn't receive more error messages. |
melmac
Joined: Aug 19, 2009 Posts: 27 Location: Schleswig-Holstein (Germany)
Posted: Sat Aug 02, 2014 10:14 am Post subject:
| pmpv wrote: | It shows 1.00 (might be software version dunno) then nL2, then the preset and it's ready to use, is this normal right?
Yes, that's absolutely normal!
| pmpv wrote: | But going back to the strange thing that was, the Roland XP10 was turned off, would really that midi interface connected to midi thru was causing this pitch bend error? Because there were no electric current on the roland, i just turned on the rack alone.
I also have/had problems with my NL2X when it is connected via MIDI and the Lead was switched on last. Sometimes it was like "dead".
I've made the experience that there are no problems when I switched on the Lead always at first. The Leads are kind of "MIDI-sensitive", I think.
But it's good to hear that your pitchbend problem is solved. |
pmpv
Posted: Sat Aug 02, 2014 5:42 pm Post subject:
Well it isn't fixed at all:
The Roland xp-10 is fine, if i only turn on the rack alone, sometimes, i get that pitch bend error too. That error is completely random.
And when it happens, it detunes the notes when i press the keys.
Another problem that i have too, is the Trig button, it doesn't blink when receives midi data neither it does a C3 note when the button is pressed.
I changed midi cable and ( recorded this video ) but the issue remains... ( pitch bend error )
Here you can also see that the trig button isn't responding at all while midi data is being received... I tried to find the nord rack 2x schematic for further analysis but with no results...
https://www.youtube.com/watch?v=mQdRuENuItc
Thanks ! |
melmac
Posted: Sun Aug 03, 2014 1:17 am Post subject:
Oh, that's really strange...
- When there is NO MIDI connection to the Rack: Does the Trig-button work/blink when pressing and is the sound "normal"?
- Do you have the possibility to look what MIDI data comes out of your Roland keyboard (e.g. MIDIOX for PC or MidiPipe für Mac)? That could help to see what happens (MIDI channels, controller data...).
- Do you have a friend or neighbour who also has a MIDI keyboard, just for testing if the Rack is behaving in the same manner with another keyboard?
- What happens if you are recording a MIDI sequence with the Roland (including pitchbend data) in your DAW (if you are using one) and then you playback this sequence with the Rack (Roland disconnected). Everything OK?
Just one thing: I remember that the Trig-LED on my (former) NL 2X Rack only went on at "Note on" (= pressing a key on the master keyboard) but not e.g. when using pitchbend or controller wheel.
Good luck, perhaps this brings you a step further.
Btw: Ask the "colleagues" in the norduserforum.com. There are "pure Nord insiders" and also some technical specialists. Surely there still also are a lot of Rack 2X users. |
pmpv
Posted: Sun Aug 03, 2014 2:28 am Post subject:
The Trig button only turns on and off when pressed, just shows a red LED, it doesn't blink when receives midi data neither it does the C3 note. ( no sound )
I already connected nord rack Midi In/out -> USB ( mac user ) and used it on logic pro, sometimes i notices that random midi data is being modified, Logic Pro shows it as parameters: 1 1 78, i think it's CC-1 which leads me to believe that what is detuning my notes is an automatic pitch bend issue that is constately bending and when this happens the pitch bend keeps sustained until i press shift + distortion ( panic button ).
I hope that i made it clear because this is a bit confusing.
No i dont, but i already have tried diferent ones: one M audio, and my Yamaha RM1X, it keeps detuning my notes... no matter what if pitch bend error appears or not. It's really a nord rack problem :S
ahh, yes, it works fine, i'll explain what i do:
I open External instrument on Logic Pro, i connect nord via MIDI In/out -> USB, then i have nord connected to a keyboard amp and this one is connected to a mixer, so when i write some notes on piano roll my nord rack plays them that work fine !!! and when i tweak nord's knobs the logic pro recognises them aswel. What is happening sometimes is the detuning notes while i'm playing and the trig button doesn't blink neither when i use a midi controler keyboard or when i use logic's pro piano roll to play the nord rack. but the sound and midi are recognised.
Since i have the nord, the trig button never blinked when i pressed the notes.
Thanks ! |
melmac
Posted: Sun Aug 03, 2014 4:16 am Post subject:
Hi again,
did you ever test if it works correctly when you are connecting the Roland keyboard directly via one MIDI cable into the Rack (without using the PC/DAW)?
Just the keyboard and the Rack, adjust the same MIDI channel on both ends and then it must work (key down = Trig-LED on, doing pitch-bend on Roland = hearing pitch-bend on the Rack), OK?
If yes, it must be a problem with the MIDI settings in Logic Pro, isn't it?
Keep us up to date. |
pmpv
Posted: Sun Aug 03, 2014 5:05 am Post subject:
The issue remains, the nord is always detuning the notes and Trig button doesn't do anything besides its LED turns on/off.
The nord and the roland were always on the same channel.
While the nord is conected via Midi in/out -> USB on Logic the problem remais...
So:
-Roland is fine.
-Logic Pro connections are fine ( cause they all work ) But the detuning notes problem remains.
My nord is faulty. |
melmac
Posted: Sun Aug 03, 2014 5:27 am Post subject:
| pmpv wrote: | | While the nord is conected via Midi in/out -> USB on Logic the problem remais... |
Sorry, but perhaps I don't understand correctly your information. Just for my clarification and to avoid some thinking errors:
- Test: please "forget" Logic, switch off the Mac, unplug the MIDI-USB-Interface.
Take a standard MIDI cable (2 x 5-pin DIN) and connect the Roland MIDI-OUT into the Nord MIDI-IN.
- Check the MIDI channels
- Play.
What happens?
Thanks! |
pmpv
Posted: Sun Aug 03, 2014 5:52 am Post subject:
| That's mostly how i work with the nord. While i'm playing, the notes keep detuning and pitch bend doesn't work. |
Joined: Apr 24, 2009 Posts: 2518 Location: Bristol UK
Audio files: 505
Posted: Sun Aug 03, 2014 6:22 am Post subject:
I would open it up to check internal connections (assuming it is out of warranty). As I have understood it, the Rack is just a Keyboard version, but modified, so there is still an internal pitch bend connection which does nothing.
Just carefully reseat connections and put it back together, or have a qualified technician do it if you are unsure about anything. _________________ Muied Lumens Sub Forum
Bandcamp |
melmac
Posted: Sun Aug 03, 2014 6:31 am Post subject:
| pmpv wrote: | | That's mostly how i work with the nord. While i'm playing, the notes keep detuning and pitch bend doesn't work. |
Thanks! Because of you have written several times that the error occurs during playing via Logic, it was not clear for me that this also happens only with the Roland connected.
In this case, I am also afraid that there is a defect of the Nord.
Nevertheless I would open it just to see if there are obvious problems inside (loose connections, cables).
As a next step: I would ask again in the norduserforum - as there are a lot of Nord experts. Perhaps someone has a new idea about this thing.
If nothings helps: professional repair... Sorry for you! |
