today> Twyndyllyngs Chez Mosc
Ground issue
Page 1 of 1 [5 Posts]
small groups
PostPosted: Fri Aug 29, 2014 9:32 am    Post subject: Ground issue Reply with quote  Mark this post and the followings unread
Hi, if anyone has a goos idea where i should start looking for what imthinkmis a ground issue. So close to getti g this thing working and i want to tell i am excited! But the gate and trig out only work if the next step is a different bus out, so that why i think theyre not dropping to zero as they should, the leds stay lit if only a single bus is being triged.
Any help would be sweet
Thanks
EdisonRex
Audio files: 172
PostPosted: Fri Sep 05, 2014 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
where do you have your digital ground connected? Straight to the power supply earth?
Garret: It's so retro.
PostPosted: Fri Sep 05, 2014 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Another possibility is that you have gate merge set?
EdisonRex
Audio files: 172
PostPosted: Fri Sep 05, 2014 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
good point, or stuck on.
have you been through the test script yet?
small groups
PostPosted: Wed Oct 01, 2014 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Turned out that the manual step switch was inverted/the wrong one. Meaning that the comparator as the clock entered the gate bus section didnt see any change, and so didnt trigger
