today> Twyndyllyngs Chez Mosc
Should I use 1 transistor array for 2 exponential converters
Page 1 of 1 [3 Posts]
okelk
PostPosted: Sun Aug 31, 2014 7:02 am    Post subject:  Should I use 1 transistor array for 2 exponential converters
Subject description: I'm building a Rene Schmitz 4069 vco!
Hi!
I want to build a dual 4069 vco (by Rene Schmitz http://www.schmitzbits.de/vco4069.html ) on one little pcb.
I replaced the pwm with a opamp version so I only need 1 cd4049 plus 1 tl074 for 2 VCOs...also the edges of the pulse wave are a bit 'sharper'.
It's working quite well on a breadboard so far...
I thought that it would be convinient to use a ca3096 (3 NPN + 2 PNP) for the two exponential converters.
My question is:
Is it ok two have two exponential converters i one packadge??
And if so, if I want to use a tempco , do I just stick both of them on op of the ca3096?
And also, would it be ok to use the 'leftover' NPN in the ca3096 for something else, or could it disturb the tempco somehow?
JovianPyx
Audio files: 224
PostPosted: Sun Aug 31, 2014 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't help with the array, but I noticed that you cited a part CD4049. I assume that you meant 4069. The circuit was designed for a 4069 and may not work correctly with 4049.
Also, it may not be advisable to put 2 VCOs on one 4069. I realize that there are enough gates, but the close internal power coupling of the two circuits on the same IC may have a problem with soft synch. There can also be a sensitivity to the exact gates that are use for schmitt trigger and integrator.
Hopefully Rene will see this.
Time flies like a banana.
corruptio optimi pessima
okelk
PostPosted: Sun Aug 31, 2014 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh...Yes,of course....I did mean the 4069...
I haven't thought of this, I only tried halve of what I want to build on a breadboard using the same pin configuration as in renes schematic...
I do remember reading in some other thread that somebody build a 4069 vco and a different pin configuration didn't work.
I guess the only way to find out is to try it.
EDIT: Oh...I just found that thread again ( http://electro-music.com/forum/topic-60189.html&postorder=asc ). You were the one where the different pin configuration didn't work!
