FS: pcbs/DIY cgs sequential switch L-1 compressor MOTM490
peng
PostPosted: Fri Sep 26, 2014 3:02 pm    Post subject: FS: pcbs/DIY cgs sequential switch L-1 compressor MOTM490 Reply with quote  Mark this post and the followings unread
Few things I need to sell:
CGS28 - Sequential Switch - bare pcb - $10
pcb is the earlier version:
http://www.cgs.synth.net/modules/cgs28v10_seq_switch.html
L-1 Microcompressor
bare pcb - $20
stuffed pcb - $40
I could never get this circuit to work.
The envelope follower portion didn't seem right.
Even on the breadboard I had problems so I gave up on these.
Many others have no problem so it could be I'm cursed.
I don't know!
The bare pcb should pose no issue.
The stuffed pcb operates and is useful but I'm not sure about the follower part.
It seems to just stay high or the comp output is oscillating or something.
Maybe it works fine or just needs some minor adjustment. No guarantee.
[/img]
MOTM-490 stuffed pcb - $50
Does NOT include the CA3280 chips (you will need three).
This is untested.
Shipping depends on where you are at.
PM me.
 Filesize:  166.02 KB
 Viewed:  4347 Time(s)
 Filesize:  248.58 KB
 Viewed:  426 Time(s)
