vladosh
Audio files: 51
Posted: Wed Oct 08, 2014 12:08 am Post subject:
Wildcat VCF-3 PCB |
Made a layout for VCF-3 from EFM's Wildcat ,it's Oberheim type VCF i built once ,liked it so i thought i'll make another ..there were two errors in the layout which i corrected ,but there's no silkscreen so if anyone's making it gonna have to follow schematic ,that's what i do )) ,for the expo pair i used BCM857 cause i had some ,you can find SMD to DIP adapter at the Buchla 258 thread ,here is schematic and ready for print layout ,it could have been done better i'm sure ,there's a 10K resistor going from the expo converter to the OTA which is missing in the schematic but is included in the layout
201.3 KB |
| Viewed: |
711 Time(s) |
962.81 KB |
| Viewed: |
1145 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
Baloo
Posted: Tue Oct 21, 2014 2:19 pm Post subject:
Thanks a lot .. I will build this one for sure never enough filters.
vladosh
Audio files: 51
Posted: Tue Oct 21, 2014 2:50 pm Post subject:
Sure Baloo , i still haven't finished mine it's almost done , happy building )) _________________ http://synthacks.blogspot.com/ шематикс |
Baloo
vladosh
Audio files: 51
vladosh
Audio files: 51
Posted: Wed Oct 22, 2014 11:49 am Post subject:
there's another error in this layout ,the 10K from output to -15 , but there is room to drill two holes and put a resistor there to fit nicely ,i will update the layout _________________ http://synthacks.blogspot.com/ шематикс |
n.d
Posted: Sun Feb 08, 2015 10:41 pm Post subject:
| Vladosh: please do, I´m very interested in this filter. |
isak
vladosh
Audio files: 51
Posted: Sat Mar 28, 2015 2:56 pm Post subject:
this is a really filter that i like , it sounds sweet , and at high resonance it's wild but not as bad like steiner can be .. this pcb layout is bit wrong ..around the expo , i never fixed it , and i lost the layout , i plan on making a oberheim sem type , but discrete ota based if i get it to work i will prolly post the layout , i used BCM transistors and rebuilt it on stripboard , i dunno how close it's to the demo you posted , it sounds nice _________________ http://synthacks.blogspot.com/ шематикс |
isak
jbeuckm
Audio files: 9
Posted: Tue Dec 01, 2015 3:01 pm Post subject:
Does the schematic above have any errors? I know that the original schemo was missing a resistor and the layout above was missing a different resistor...
Update: I'm thinking that the 4600 series are more refined than the Wildcat was. I am working mainly from the 4621 and have started 4622:
https://github.com/jbeuckm/EFM_VCF3
https://github.com/jbeuckm/EFM_VCF_4622 |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Tue Dec 08, 2015 4:13 am Post subject:
Hey Joe,
Found your eagle files of the wildcat ringmod you did on github. I reworked them to the other ringmod on Yves Usson's site
"Look Ma, no wiring"
Jacks are Thonkiconn, and PCB dims are 50x62 (mm). |
isak
Posted: Wed Dec 09, 2015 12:55 am Post subject:
Hi guys.
Does enybody knows if the mention EMF multiband VCF above is self oscilating in LP or HP mode? _________________ http://www.myspace.com/mgmtrance |
bamboombaps
Posted: Sat Dec 12, 2015 9:15 am Post subject:
hey great work! is it possible to share these eagle files?
| LFLab wrote: | Hey Joe,
LFLab
Posted: Sat Dec 12, 2015 9:20 am Post subject:
| Sure, I am going to look into getting this into github, so everybody can access the files. |
bamboombaps
Posted: Sat Dec 12, 2015 9:26 am Post subject:
isak
Posted: Thu Jun 29, 2017 8:39 am Post subject:
| jbeuckm wrote: | Does the schematic above have any errors? I know that the original schemo was missing a resistor and the layout above was missing a different resistor...
Hi jbeuckm did you ever built the VCF3 you posted over the git?
Isak. _________________ http://www.myspace.com/mgmtrance |
