isak
exagonal
Posted: Sun Oct 12, 2014 6:12 am Post subject:
Hello everyone!
I undertook the project of DIY a TR 808 clone of using the project MICROLARGE that I found online, and exactly to the 'xxx address.
Some time ago I started to dump me some project files for convenience, but now that I've decided to start the installation I realized that some files are missing on the schematics.
Going therefore into the site to view and download these files, I realize with astonishment that, unfortunately, the site is no more, apparently it was closed!
I searched in vain in the network if the project had changed location, but nothing to do ..
It is not by chance that someone here has a backup of the site in question?
I'd be grateful ...
Thanks! |
isak
exagonal
Posted: Sun Oct 12, 2014 8:18 am Post subject:
WOW !!!
Thank you very much isak !!
Your " wayback machine " it's amazing !! |
isak
exagonal
Posted: Sun Oct 12, 2014 10:13 pm Post subject:
Dear friend,
The web database is very cool, but I'm still not to be able to find the schematics files of the microlarge 808 clone.
Anyone out there maybe has this files, or they're originally stolen??
Thank for every answer... |
exagonal
Posted: Sun Oct 12, 2014 10:21 pm Post subject:
Otherwise, you are just built the 808 clone with mods? For 2.2 M logarithmic pot ? I'm find nothing and I think that's no commercial value..WTF??
Also, I'm interesting in a sequencer, but nothing found simply and with all documents integrated... Any suggestions? |
isak
Posted: Sun Oct 12, 2014 10:59 pm Post subject:
hi again.
i think i have all the schemes of the 808 from microLARGE, i'll check it later on when i'll get home.
i built only the 808BD so i cant help with other modules build, sorry.
Isak E. _________________ http://www.myspace.com/mgmtrance |
exagonal
Posted: Mon Oct 13, 2014 6:14 am Post subject:
| Thank you isak ! |
isak
exagonal
Posted: Mon Oct 13, 2014 8:04 am Post subject:
WOW !! You're great MAN !!
Thank you very very mutch! Now I think I have everything i need, except the part of the sequencer, of course ... and then there would be the mystery of the 2,2 Megaohm potentiometers... |
isak
Posted: Mon Oct 13, 2014 8:36 am Post subject:
Happy I helped out here.
Please update and upload pics of the project
exagonal
Posted: Mon Oct 13, 2014 8:48 am Post subject:
Sure!
I have already built a successful TR 9090 emulator 909 ...
| Description: |
| Filesize: |
592.13 KB |
| Viewed: |
252 Time(s) |
| Description: |
| Filesize: |
669.96 KB |
| Viewed: |
231 Time(s) |
isak
exagonal
Posted: Mon Oct 13, 2014 11:10 am Post subject:
Ehehehe! Thank you ! This last summer I sweat a lot doing this machinery
I bought the kit on this site :
http://www.synthage.com/frontpanel/frontpanel.php
but had not yet the aluminum panels.
I purchased the houses apart and applied the shield on, then drilled ...
hard work!
isak
exagonal
Posted: Mon Oct 13, 2014 12:11 pm Post subject:
Thank you again!
Right now, however, I have set out to clone the BOSS DR 110.
Are in the planning stage but I'm a bit stranded ... I'm looking for a solution to get simply the trigger for the CLAP. |
isak
Posted: Mon Oct 13, 2014 1:17 pm Post subject:
What would be the trigger source?
Did you trigger all the rest of the modules? _________________ http://www.myspace.com/mgmtrance |
exagonal
Posted: Mon Oct 13, 2014 1:32 pm Post subject:
| I'm planning to connect everything to a simple MIDI to trigger, which then generate the trigger for all the sounds, positive of course, but the changes already know them ... I would like to resolve the triggering planning a small PIC ... |
isak
Posted: Mon Oct 13, 2014 1:49 pm Post subject:
When I did my kickbox project 808&909 BD in the same box I used Arduino UNO to make midi to gate and trigger.
I actually built the arduino on stripboard, called stripduino.
I can give you the code for that if you want, I just need to find it on the hardrive.
Check the vid clip (in Hebrew, but you'll get the point)
https://youtube.com/watch?v=9TWDkXDlbUg _________________ http://www.myspace.com/mgmtrance |
