Median of an array
Page 1 of 1 [25 Posts]
Moody33
G2 patch files: 16
PostPosted: Tue Oct 14, 2014 6:35 am    Post subject: Median of an array Reply with quote  Mark this post and the followings unread
Hi all.
I've build a median algorithm. It search for the median (median is not the mean values) between 3 values. I'd like to find an economic solution to find the median between 5, 7 or more values (and not the median of the median, this is possible by duplicated my initial algo in series). Any ideas? Here is my patch.
Thanks.
median.pch2
 Filename:  median.pch2
 Filesize:  1.42 KB
 Downloaded:  4248 Time(s)
Audio files: 297
PostPosted: Tue Oct 14, 2014 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I have no idea as to how to do that for the G2 ... I think I would try the same approach as you used - figure out the selection with comparators .. but it gets large quickly with the sorting needed.
Anyway, I got curious as to what you would use the median calculation for .. just for filtering data, or for a direct musical result?
Just thought it might be interesting to, for example, filter a sequence through a median filter and get the result as a new VCO frequency .. for an extra voice related to but not equal to the sequenced voice ... I made a module for it for my softsynth to test that idea .. I like it Smile
Moody33
G2 patch files: 16
PostPosted: Tue Oct 14, 2014 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Blue Hell!
In fact, I often used the G2 as a game...So I built this for fun...But you can use the Median algo if you want to skip jump in values and keep the most important and redundant values ...This can be useful in many situation, especially in pitch tracking, but my algo is too short ( array of 3 values) for this application. Sorting the array is not really necessary since we just want the median. There is some article on the net related to fast median algo, but my brain can't deal with math stuff and english is not my native language... So if you are interested, you can take a look.
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Oct 14, 2014 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use bubblesort approach with cascaded min/max modules (as described in the editor help section) and pick the middle value.
Moody33
G2 patch files: 16
PostPosted: Tue Oct 14, 2014 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good idea Tim, I will take a look. But bubblesort seems to be interesting for a few elements. I guess if a kind of recursive algo is possible to find the Median between more than 5 values?
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Oct 14, 2014 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably, but it won't update at the system rate (either control or audio) anymore, as every recursion will introduce one sample of delay.
Moody33
G2 patch files: 16
PostPosted: Tue Oct 14, 2014 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
This isn't a problem, any suggestions?
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking about it. Mr. Green
(I have something on the workbench, but no guarantee yet if it will work.)
Moody33
G2 patch files: 16
PostPosted: Wed Oct 15, 2014 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah! Nice ! wave beer
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
*delete*
Moody33
G2 patch files: 16
PostPosted: Wed Oct 15, 2014 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a first viable approach for 7 values (expandable):
Thanks Tim, but it don't seems to work. I've set the 6 first value to 64 and -64, the 6th to 1 and if I tweak the 7th one, your patch seems to output the 7th value and not the median which is the 6th element. Confused
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for testing it. You're right.
Guess I was too over-confident. Embarassed Laughing I deleted the building block thread.
I know what the mistake is. Don't know yet if I can fix it. Sorry.
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I fixed it. Just needed another treacle-down stage.
Could you please test it again? I won't publish it in the building blocks section until it's 100% robust.
Thanks alot.
cheers
EDIT: It really seems to work now. But please be aware that if the inputted values are highly dynamic, the circuit might not always render the correct result because of the 1.666 ms update cycle. For dynamic input values, one has snap them to the circuit with a bank of S/H modules before the multiplexer, which are clocked by the counter reset pulse (the only yellow cable in the patch).
EDIT2: I added the required S/H bank described above. New version.
EDIT3: I miscalculated the refresh time too. It's way faster. 0.291ms, even at control rate.
EDIT4: As it works, I moved the patch to the building blocks section:
www.electro-music.com/forum/post-404322.html
EDIT5: A further understanding of the patch shows that there is no real benefit in terms of update accuracy by implementing the mentioned S/H stages, so I ditched them again.
Moody33
G2 patch files: 16
PostPosted: Wed Oct 15, 2014 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems to works perfectly! Very Happy
The amount of memory is quite high but I don't think we can build a more efficient method due to the amount of math required to get the median value.
Nice work Tim thanks
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
The update rate is quite fast (0.291 ms, 28 samples @ 96k or 7 samples at 24k) and if the input values aren't highly dynamic, and/or the result doesn't have to be absolutely 100% correct all the time, one can do away with the S/H modules and save some mem%.
Thanks too. This afternoon I didn't even know yet what a median was. This was fun. Smile
Moody33
G2 patch files: 16
PostPosted: Wed Oct 15, 2014 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
This could be very useful for your pitch tracking algo I guess, It could be efficient with more values, or perhaps with the median of the median? Wink
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Oct 15, 2014 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know nothing about the relationship between median values and pitch-tracking. Embarassed Do you have any useful links?
Audio files: 297
PostPosted: Wed Oct 15, 2014 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tim,
The idea is that median filtering gets rid of unlikely values .. so when you have jittery signals the median usually is closer to the real value .. or the wanted value ... so .. for your pitch tracker it might make the output better for rapid pitch changes .. with less need of careful parameter setting.
Moody33
G2 patch files: 16
PostPosted: Wed Oct 15, 2014 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
No link sorry, but as I said to Blue Hell, the Median allow to skip jump in values and keep the most important and redundant values. I think the median value could avoid detection error during a pitch tracking, especially when the zero-cross counter jump to the second harmonic of the audio source which is often strong.
For example, the first harmonic is detected during 8 cycles and the second during 2 or 3 cycles before returning to the right pitch during 8 cycles again. If a median of 16 values is applied, those 2 or 3 cycles should be ignored. But if we apply a median of 3 values , those 2 or 3 cycles won't be ignored. Sorry for my bad english but I'm sure you understand what I mean...
This is just an idea!
Moody33
G2 patch files: 16
PostPosted: Wed Oct 15, 2014 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooops, I've not seen Blue Hell's reply which is short but clear! Laughing
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Oct 16, 2014 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Guys, this is fascinating stuff! Thanks so much for your explanations.
I didn't think of feeding the circuit with a moving window of data. Although, now that I think back to your patch Moody33, it was in front of my eyes (the shift register). doh Laughing
I'll need some time to ponder the deeper possibilities of this kind of data processing.
t
Audio files: 297
PostPosted: Thu Oct 16, 2014 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I experimented a bit, short running median filtering is nice for generating a 2nd sequenced line from the main sequence.
It depends a bit on the sequence length what still is useful for the median queue size (for this purpose).
I used values from 3 .. 11 sofar with a sequence of 14 steps (in which a note gets changed every now and then). Should be nice on totally random note sequences too.
Moody33
G2 patch files: 16
PostPosted: Thu Oct 16, 2014 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell,
I've also experiment this approach ( and my patch illustrated quickly this idea ) but, to my ears it generates harmonics conflict. It's often better to pitch up the second line to avoid minor/major 2nd relation. And finally , the idea is quite similar to a delay line, but the delay line effect is much better logical for our ear in my opinion.
Moody33
G2 patch files: 16
PostPosted: Thu Oct 16, 2014 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Here an article about fast median algo with schematics using gates and shift register :
http://www.uio.no/studier/emner/matnat/ifi/INF2310/v12/undervisningsmateriale/artikler/Danielsson-median.pdf
Simply chinese for me Embarassed
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Oct 16, 2014 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
"For those from Missouri..." is my favourite line in there.
But yeah, it does look nasty. Twisted Evil
Maybe I'm from Missouri too. Shocked Laughing
