 Forum index » Online Music
Musics for sun and moon
Page 1 of 1 [5 Posts]
Audio files: 299
PostPosted: Thu Oct 23, 2014 4:53 pm    Post subject: Musics for sun and moon Reply with quote  Mark this post and the followings unread
First here was a scream, then there was a ligtht.
All according to http://eclipse.gsfc.nasa.gov/solar.html
the date was 2014, October 23
PHOBoS started streaming - I mixed it all up somehow.
"This is the 9th eclipse of Saros 153 (Espenak and Meeus, 2006). The series began on 1870 Jul 28 with a string of 13 partial eclipses. The first of 49 annular eclipses begins on 2104 Dec 17. The series ends with a set of 8 partial eclipses the last of which occurs on 3114 Aug 22. In all, Saros 153 produces 70 solar eclipses in the sequence of 13 partial, 49 annular, and 8 partial eclipses.
2014-10-23--PHOBoS blue hell--moon and sun dance 1.mp3
First here was a scream, then there was a light 1
 Filename:  2014-10-23--PHOBoS blue hell--moon and sun dance 1.mp3
 Filesize:  40.61 MB
 Downloaded:  3489 Time(s)
2014-10-23--PHOBoS blue hell--moon and sun dance 2.mp3
First here was a scream, then there was a light 2
 Filename:  2014-10-23--PHOBoS blue hell--moon and sun dance 2.mp3
 Filesize:  6.89 MB
 Downloaded:  3494 Time(s)
JovianPyx
Audio files: 224
PostPosted: Thu Oct 23, 2014 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some photographs:
http://scott.joviansynth.com/eclipse_10_23_2014/
The images of the eclipse were photographed using a pinhole in foil to project an image on paper which I photographed with a low cost digital camera. There is at least one photograph of the setup for that. 3 of the images show a wall where the sun filtered through plant leaves first. The plant leaves formed enough of a "pinhole" lens to capture the image of the eclipse as a projection on the wall.
Time flies like a banana.
corruptio optimi pessima
PostPosted: Fri Oct 24, 2014 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice mix jan Very Happy, thanks for recording (apparently I forgot Rolling Eyes )
edit: added some artwork, thanks for the photos Scott!
Cover Art
 Filesize:  894.48 KB
 Viewed:  668 Time(s)
Audio files: 299
PostPosted: Fri Oct 24, 2014 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Forgot ... wow .. I thought you had it always on.
Thanks! and thank you Smile
Nice apparatus and pics Scott Cool
PostPosted: Sun Oct 26, 2014 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome stuff - music and pics.
The sun was behind buildings here, so I couldn't watch even if I had the means.
