 Forum index » Instruments and Equipment » Samplers
a far out question...possibly the wrong section.
Page 1 of 1 [5 Posts]
edjwise
PostPosted: Sat Jan 28, 2012 8:55 pm    Post subject: a far out question...possibly the wrong section. Reply with quote  Mark this post and the followings unread
Im looking for a looper, something that works in real time for loop capture much like a sampler...but I want it to be a multi track too so that I can loop, mix, slice all on the fly.
For years I thought that a SP808 would kinda do this, when I saw that it only records one track at a time I felt a bit let down.
Is their a multi input sampler?
What about a hard disk recorder that can act like a sampler with looping etc?
I need something that can sync to midi at least, being able to control the tracks like samples via midi would be amazing.
Keysandslots
PostPosted: Sat Jan 28, 2012 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might want to look at some of the iPad apps that are available. This is cool http://www.analogindustries.com/blog/entry.php?blogid=1322259858415 but probably not exactly what you wanted. Might give you some ideas 'though.
Randy
PostPosted: Sun Jan 29, 2012 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Octatrack or Ableton Live?
DrLoK
PostPosted: Fri Dec 19, 2014 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe the Electrix Repeater does what ur looking for. Didn't check to see how old this thread is before posting.
DES
PostPosted: Sat Dec 27, 2014 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Mobius might work for you. It's a very capable multi-track looper, and I believe it can record and output on different audio channels and sync to MIDI. You can also load prerecorded loops and trigger them. Includes a full compliment of functions: reverse, speed changes, etc. AND also has a very comprehensive scripting ability. The developer is very responsive to problems.. Shortcomings? It doesn't have the best gui interface and it does require a PC or Mac...
Oh, forgot to mention... its FREE Very Happy
http://www.circularlabs.com/download2/download.html
www.davesneed.com
