King Rat
G2 patch files: 13
Posted: Thu May 19, 2005 7:03 am Post subject:
Replicating Reaktor and Absynth sounds |
I know that they are very different beasts from my G2 and the sounds are bound to be different, but there are a few sounds in these soft synths that I'd love to approximate on the G2.
However, I can't even get close in most instances. I don't know whether this is due to my limitations or G2 limitations - I suspect the former.
Here's an example from Reaktor. A very easy-to-reproduce sound (output clean.mp3) processed by a sequenced delay unit (output 1-2.mp3). I can't get close to emulating that delay unit sound. It's basically a couple of step sequencer controlled delay units in series, the first one set to modulate to produce small blips in the sound which are then echoed by the second unit. There's also some modulated filtering going on to keep the underlying pad evolving.
Any tips on how to approach this sort of sound???
Thanks and sorry for the vagueness of the question.
Angus
| Description: |
 Download (listen) |
| Filename: |
Output clean.mp3 |
| Filesize: |
171.94 KB |
| Downloaded: |
1291 Time(s) |
| Description: |
| Audio processed by delay unit |
 Download (listen) |
| Filename: |
Output 1-2.mp3 |
| Filesize: |
171.94 KB |
| Downloaded: |
1252 Time(s) |
King Rat
G2 patch files: 13
Joined: Jan 31, 2003 Posts: 18286 Location: Durham, NC
Audio files: 235
Posted: Thu May 19, 2005 11:15 am Post subject:
I wish I had the time to help you with this, but I'm swamped with prep for the electro-music 2005 thing. The mp3 doesn't sound all that different from things I've heard from some of the submitted patches here on the forum though. On second thought, even if I had the time I probably wouldn't be too good at this sort of thing. I patch to find sounds I've never heard before and then use those in my music. Anyway, good luck, Angus. _________________ --Howard
my music and other stuff |
3phase
G2 patch files: 141
Posted: Thu May 19, 2005 11:53 am Post subject:
Its probably possible to get close.. as long no allpass filters are used in reaktor...
and no high resonance settings in the filters... on resonant settings the reaktor moduls get in strange states that actually can sound nice...
maybe possible to patch that...
I would like to have the old Bi-machine patch for the G2..
one of the oldest and most simple reaktor patches.
My first trys showed me that the filtersound will need a handfull of modules.. |
Afro88
Joined: Jun 20, 2004 Posts: 701 Location: Brisbane, Australia
Audio files: 12
G2 patch files: 79
Posted: Thu May 19, 2005 4:05 pm Post subject:
To me it sounds like the step sequencer controls the delay time. The little glitches in the audio happen when the sequencer changes the delay time. Basically each step in the sequence changes the delay time momentarily, only for say 100ms or something. Then this feeds into a low pass filter and finally into a stereo delay. I think there's some dry signal getting fed into the filter or second delay too.
I guess you would have to set up a value sequencer with a trigger control. The trigger control would open up an AHD envelope to let the delay time change for a short period of time. Then you could select which steps the glitches happen on. It sounds to me like the delay times being used for glitches are quite high too. This delay line would also need a fair bit of feedback. The lowpass filter is there to keep the delay line under control. It may or may not be patched into the feedback loop....
Sorry if you had already figured out alot of this, I had to put it all down to think it through myself. Hope it helps. |
Joined: Apr 03, 2004 Posts: 24623 Location: The Netherlands, Enschede
Audio files: 317
King Rat
G2 patch files: 13
Posted: Thu May 19, 2005 4:38 pm Post subject:
Excellent - will play around with some of these ideas.
Thanks for the responses.
Angus |
triptonizer
King Rat
G2 patch files: 13
triptonizer
Posted: Fri May 20, 2005 8:35 am Post subject:
hum.. that's quite a complex fx unit
but I'm sure it could be done *in principle*, would be quite a challenge though... maybe - just maybe - I'll have a closer look if I find time tonight.
btw - do you get error messages like me when trying to download attachments? -> mosc  |
rnp
Posted: Fri May 20, 2005 8:53 am Post subject:
I do for what it's worth =/ _________________ http://www.regicide.org
deer music
offering temporary solutions |
G2 patch files: 626
Posted: Fri May 20, 2005 10:45 am Post subject:
| triptonizer wrote: | btw - do you get error messages like me when trying to download attachments? -> mosc  |
Downloads are broken, File server? |
