modular
Joined: Jul 26, 2004 Posts: 185 Location: Rome, Italy
G2 patch files: 72
Joined: Apr 03, 2004 Posts: 24496 Location: The Netherlands, Enschede
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat Aug 07, 2004 1:38 am Post subject:
It seems like doing 'on the run' is some sort of G1 tradition.
I just spent some enjoyable time researching the little EMS synthesisers, the VCS3 and the suitcase-like Synthi-A. I never played one but always admired the design.
They have a quirky envelope, capable of self-triggering but otherwise, an AHR type. The 3 oscillators (#3 is biased toward LFO type use) each have two mixable waveforms and a shape control. Oscillator 1 has ramp and a variable sine, the alternate sine shape is simply a full wave rectified sine.
The filter is (reportedly) a little bland and unassuming, early (pre 1974) units had an 18dB slope and they all had a slight slew problem (frequency slow to change with fast CV).
And must not forget that wonderful patch panel, where replacement pins cost more than decent patch cords and you have to retune the oscillators after making a new connection
So armed with all my research and a fresh copy of Dark Side Of The Moon, I have done a little G2 'on the run'. It sort of takes care of itself but if you feel the need, Filter cutoff is morphed to the mod wheel.
I think the origional was multitracked unless he had 3 or more synthi-A's
 Download (listen) |
| Filename: |
DARKNOODLE2.pch2 |
6.77 KB |
| Downloaded: |
2948 Time(s) |
modular
G2 patch files: 72
Posted: Sat Aug 07, 2004 2:54 am Post subject:
This exactly is!
Thanks one time again g2ian  |
Posted: Sat Aug 07, 2004 5:34 am Post subject:
Very very close Ian !
The highhats might need some extra tweaking, guess it's a real drummer on the record (the speed seems to vary a bit ?). And then of course the scratches and ticks my record has :-)
I tried putting in a metal noise osc instead of the regular noise, but that one costs a bit too much unfortunately.
This patch brings my laptop to a grinding halt, it's almost untweakable for me - maybe it thinks it to hot to compute (it would be quite right about that).
Jan. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Mon Aug 09, 2004 4:19 am Post subject:
Thanks for the comments guys, and the advice Jan. I just updated the post (DARKNOODLE2) with some minor changes.
Shifted the HiHat and background noise into the FX area, freeing some dsp and allowing small improvements. The hats now use a separate metal oscillator and are humanised with slow random lfo waves for velocity and timing (using mod delays). The background noise gets just a little more complicated with a randomB generator.
In the main section have just added a couple of modulated pan modules to shift Synthi 2 and 3 around in space. The timeline LFO has also been slowed to about a minute.
Hopefully it will be more tweakable now as well . |
Posted: Mon Aug 09, 2004 9:22 am Post subject:
| g2ian wrote: | | I just updated the post (DARKNOODLE2) with some minor changes.. |
I knew you would, too much silence happened :-)
I'm at work now, but I'll certainly check it out this evening.
(*later, at home, but the sun is the same, ehm, relative, older*)
Wow, this is so close I can almost hear the voices and the footsteps, excellent !
Jan. |
cappy2112
Joined: Dec 24, 2004 Posts: 2499 Location: San Jose, California
Posted: Sat Jul 21, 2007 6:14 pm Post subject:
| g2ian wrote: | :
I think the origional was multitracked unless he had 3 or more synthi-A's |
wow- how did I miss this thread?
I have a DSOTM DVD documentary where Dave Gilmore talks about how that sequence was created. He doesn't go into much detail though, regarding filters, oscs, etc, but it's interesting to hear/see first hand.
I wish I could make a copy of that DVD sequence and post it. |
Posted: Sun Jul 22, 2007 1:54 pm Post subject:
| cappy2112 wrote: | | I have a DSOTM DVD documentary where Dave Gilmore talks about how that sequence was created. |
Saw that one.
| Quote: | | He doesn't go into much detail though, regarding filters, oscs, etc, but it's interesting to hear/see first hand. |
But it has a nice buildup with running it slower and faster making it easier to hear what is going on - it seemed very natural in the movie
Glad to see you're home again safe. _________________ Jan
cappy2112
Posted: Thu Jul 26, 2007 10:24 pm Post subject:
[quote="Blue Hell"] | cappy2112 wrote: | | I have a DSOTM DVD documentary where Dave Gilmore talks about how that sequence was created. |
Saw that one.
Glad to see you're home again safe.[/quote
I have also seen a similar one where Townsend shows how the arpeggiator sequence in "Won't Get Fooled Again" (or was it Baba Oreilly?) was done with an Arp 2600.
I think this one is also on YouTube
(of course, what isn't on You Tube these days?) |
derekrevell
Joined: Mar 22, 2008 Posts: 33 Location: London, U.K.
Posted: Mon Feb 16, 2015 9:43 am Post subject:
On the run on Synthi AKS Subject description: How it was done |
| Blue Hell wrote: | Very very close Ian !
Jan. |
Well as far as I know, the "High Hats" you refer to, were actually a sound generated on the Synthi at the same time as the sequence, the trigger pulse from the sequencer is fed to the A input of the Ring Modulator. and the B input is fed from the Noise Generator with the colour set around 3.
The output from the Ring Mod is then fed in the Filter which is a 4th Order type filter producing 24db/Oct, the EMS filter has always been a 24db/oct, although the EMS spec sheet says 18db/Oct, this was only stated as such to avoid litigation from Moog, the EMS filter uses Diodes instead of Transistors, but it's still a 4 Pole Filter, check the circuit diagram if you don't believe me. _________________ If it isn't broken, don't attempt to fix it. |
Posted: Mon Feb 16, 2015 1:21 pm Post subject:
hmm I'd love to hear it but even if it would on the run run on the demo (no idea) the demo doesn't really run on my computer.
However I don't know if there would be any copyright issues with it. If not than I have a version somewhere myself I could
upload (not G2 though) and I know Blue Hell played with it too. _________________ "My perf, it's full of holes!"
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Mon Feb 16, 2015 7:53 pm Post subject:
Re: On the run on Synthi AKS Subject description: How it was done |
| derekrevell wrote: | | ...The output from the Ring Mod is then fed in the Filter which is a 4th Order type filter producing 24db/Oct, the EMS filter has always been a 24db/oct, although the EMS spec sheet says 18db/Oct, this was only stated as such to avoid litigation from Moog, the EMS filter uses Diodes instead of Transistors, but it's still a 4 Pole Filter, check the circuit diagram if you don't believe me. |
Yes, the EMS diode ladder is a 4 pole/24dB LPF. So, for EMS to claim that it is an 18dB LPF is not true. But, as Tim Stinchcombe showed in his analysis of the frequency response of EMS vs. the Moog transistor ladder, the EMS filter has a noticeably rounder roll off curve at the corner frequency when the filters are set at lowest resonance. This would suggest that the EMS filter would cut some high frequencies just as they approached the corner, but would allow more highs to pass above the corner frequency when compared to the Moog. That would give the audible impression of something less than a 24dB slope. But, as the resonance of these filters is increased, I would suspect that the sound of the EMS would start to come closer to matching the 24dB slope of the Moog.
It’s too bad that the G2 does not have a filter module intended to emulate the sound of famous diode ladder filters like the ones used in the EMS synths and TB-303. But, the G2 Classic Filter module (a G2 emulation of the Moog ladder filter) seems to come much closer to sounding like the diode ladder filters than any other G2 filter module.
And thanks to this Pink Floyd On the Run topic being bumped up to the top, I now have an easy excuse to put my Dark Side of the Moon CD in the player and spin it for what must be more than the 1000th plus time…  _________________ varice |
varice
Audio files: 29
G2 patch files: 54
Posted: Mon Feb 16, 2015 8:20 pm Post subject:
| PHOBoS wrote: | hmm I'd love to hear it but even if it would on the run run on the demo (no idea) the demo doesn't really run on my computer... |
WTF I just tried to load the DARKNOODLE2 patch into the G2 Demo on a relatively powerful Windows 7 Pro computer, but the Demo fails to run (Demo Voice Mode indicator goes RED), but the patch runs just fine on the hardware...
| PHOBoS wrote: | However I don't know if there would be any copyright issues with it. If not than I have a version somewhere myself I could
upload (not G2 though) and I know Blue Hell played with it too. |
Ummm, a version of "what" are you refering to? _________________ varice |
ian-s
Audio files: 42
G2 patch files: 626
varice
Audio files: 29
G2 patch files: 54
Posted: Mon Feb 16, 2015 10:39 pm Post subject:
| ian-s wrote: | | ...I think that the Demo is strictly a one dsp deal. If the total VA + FX > 100% then it won't work. |
I had mistakenly thought that the G2 Demo would give 100% in the VA and 100% in the FX area. But that seems to be not true… _________________ varice |
Posted: Tue Feb 17, 2015 3:33 am Post subject:
Starting to look like the real thing more and more :-) _________________ Jan
Posted: Tue Feb 17, 2015 3:38 am Post subject:
| varice wrote: | | PHOBoS wrote: | hmm I'd love to hear it but even if it would on the run run on the demo (no idea) the demo doesn't really run on my computer... |
WTF I just tried to load the DARKNOODLE2 patch into the G2 Demo on a relatively powerful Windows 7 Pro computer, but the Demo fails to run (Demo Voice Mode indicator goes RED), but the patch runs just fine on the hardware... |
In my case it's not so much that it doesn't run just that I don't have a powerful PC so I can only play a small patch.
| Quote: | | PHOBoS wrote: | However I don't know if there would be any copyright issues with it. If not than I have a version somewhere myself I could
Ummm, a version of "what" are you refering to? |
a version of on the run
But I looked up what i had yesterday and I really don't think it's worth posting,
I thought it had a longer section that sounded ok.
Wasn't trying to do a cover just testing a sequencer.
However I do want to make a Dark Side of the Moon Base someday. _________________ "My perf, it's full of holes!"
varice
Audio files: 29
G2 patch files: 54
Posted: Tue Feb 17, 2015 7:20 pm Post subject:
| PHOBoS wrote: | | varice wrote: | | ...Ummm, a version of "what" are you refering to? |
a version of on the run |
Silly me… I may be more of a nerd than I thought I was. I read the word version and this pops into my head: software version?... patch version?...  _________________ varice |
