today> Various Artists September equinox Concert
Siemens Sitral Modules
Page 1 of 1 [8 Posts]
indeep
PostPosted: Mon Jan 13, 2014 8:25 am    Post subject: Siemens Sitral Modules
Subject description: Some of my Sitral Modules for sale
Modules of my Sitral now for sale, i have kept a few for a new mixing desk, and this are the ones that im selling.
All of them are in good condition and most important..working.
I can send pictures of the modules and these prices can be discussed.
Also if you are into trades and have something that worth looking ..send me an email...im always looking for new stuff, microphones, modular stuff synths.
As for shipping i will ship worldwide, but the buyer pay the shipping and insurance.
If anyone as any questions about these pls send me an email
W295B(X2)
SOLD
Equalizer with Presence/absent Filter
350€
"An active equalizer for adjustment of the frequency characteristic or cutting the required frequency band. On the front panel are eleven position switches for the adjustment of the high and low frequency equalizers and two switches for setting the presence and absent filter."
W294(X1)
Variable Low-Pass Filter
320€
"A treble and cut filter and amplifier unit with the cut-off frequency adjustable over nine octave steps.
Will form a variable bandpass filter when used with the High-pass filter."A
W293(X1)
Variable High-pass Filter
320€
"A Bass cut filter and amplifier unit with the cut-off frequency adjustable over nine half octave steps.Will form a variable bandpass filter when used with the Low-pass Filter"
V276(X2)
SOLD
Pre-Amplifier
300€
"An Amplifier with one input and one output for use with condenser and dynamic microphones.On the front panel are fine and coarse gain controls and an impact sound filter control.
V275/0(XCool
SOLD 2 STILL HAVE 6
Amplifier Line
100€
"A mixing amplifier for a maximum of 30 input channels.
The coupling resistors are mounted external to the amplifier on the connection panel."
Inputs: Transformer floating
Input impedance : with 7 to 20db gain 12 Ohms
with 13 to 26db gain 3kOhms"
H280(X1)
SOLD
Test Tone Generator
220€
"A tone Generator with 5 frequencies which can be selected by push buttons, three outputs, for testing high fidelity levels on setting levels on mixer and lines"
U271(X3)
SOLD 1 STILL HAVE 2
Level Metering Amplifier
150€
"A metering amplifier with two inputs (one for signal reference to be measured and another for reference signal), and two outputs for connection to 1 pointer type meter or 1 light spot meter or two spot light meter or 1 pointer type and 1 spot meter to DIN 45406"
U274(X2)
SOLD
Talk-back Pre-amplifier
120€
"Amplifier providing limiting of the dynamic range.
The gain are adjustable in steps"
W-VE16(XCool
SOLD
Geiling Flat Fader
70€
"The Geiling Flat Fader is a balanced potential divider with oppositely running potentiometers and common electrical earth, the core have annular-core and parallel carbon track"
V257(X1)
SOLD
Optical Sound Replay Amplifier
210€
"An amplifier for connection to a semiconductor photocell.When scanning a fully modulated optical sound track, an output voltage is required. In case of optical sound prints with very low noise level, the frequency range can be extended to aprox. 7500Hz by mean of built-in relay and treble controls"
I can send pictures of the modules, they are tested and running.
 Filesize:  694.69 KB
 Viewed:  563 Time(s)
 Filesize:  693.31 KB
 Viewed:  502 Time(s)
 Filesize:  674.45 KB
 Viewed:  532 Time(s)
 Filesize:  736.62 KB
 Viewed:  592 Time(s)
 Filesize:  648.54 KB
 Viewed:  546 Time(s)
indeep
PostPosted: Wed Jan 15, 2014 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pics added.
indeep
PostPosted: Tue Jan 28, 2014 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
H280(X1) SOLD
Test Tone Generator
V257(X1) SOLD
indeep
PostPosted: Fri Feb 20, 2015 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I still have some modules Geiling Analog Faders and stuff.
indeep
PostPosted: Wed Sep 30, 2015 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Updated
spirosekulovski
PostPosted: Wed Apr 24, 2024 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
indeep wrote:
Updated
I'm aware this is a very old topic but, do you still have U271 Level Metering Amplifier modules for sale? I need two of them for my Siemens B-J45 meters.
indeep
PostPosted: Wed Apr 24, 2024 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Let me check tonight at the studio.
indeep
PostPosted: Wed Apr 24, 2024 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, still have.
 Filesize:  2.37 MB
 Viewed:  90 Time(s)
