MM editor will not recognise midi ports
Page 1 of 1 [3 Posts]
markdireland
PostPosted: Fri Mar 06, 2015 3:54 pm    Post subject: MM editor will not recognise midi ports Reply with quote  Mark this post and the followings unread
I am running the Editor as Win 98 compatible and it hangs while 'still looking'
for the midi port.
Playing the MM with midi is working fine.
PostPosted: Fri Mar 06, 2015 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. yes .. it is critical on the MIDI inteerface .. you may have to try some Confused
Working OK here on windows 8.1 with edirol um3ex ...
It may also be a cable issue.
You could also try other compatibility modes.
markdireland
PostPosted: Sat Mar 07, 2015 3:37 pm    Post subject: MM editor will not recognise midi ports Reply with quote  Mark this post and the followings unread
I wonder if some other program is hogging the port?
I dont have any music software running while using the editor.
