Using a Wall Wart, and capacitor equivalents
Page 1 of 1 [10 Posts]
inverseroom
PostPosted: Sun May 15, 2005 7:16 am    Post subject: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
Hi there--
I tried emailing Ray, but it came back. Perhaps you all can help me. My Mini-Synth is coming along great; however, I have a couple of questions...
1) I think I'm going to just use a wall-wart and power conditioner instead of batteries, or perhaps in addition to them. Should it be 9v or 18v?
2) C1 is listed as .001uf. C8 and C9 are listed as 1000pf. Aren't these the same thing, the caps marked 102? I just used the same part in each place, correct me if I'm wrong about it.
Thanks, y'all...
John.
radfaraf
PostPosted: Sun May 15, 2005 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
According to my math C8 and C9 are the same too. Shocked
dnny
PostPosted: Sun May 15, 2005 1:20 pm    Post subject: Re: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
inverseroom wrote:
Hi there--
the power supply should be +/-9v
Ray wrote:
I recommend that you don't apply voltage greater than 9 volts to the inputs or you may damage the components.
i dont know if you can make +/- 9V psu by hooking up two +9v transformers as shown Here
if someone knows please tell us.
the capacitors are the same. so no need to change those
nice conversions table pikos,nanos,micros and so on:
http://www.sengpielaudio.com/ConvPrefe.htm
daniel
ladislaobiro
PostPosted: Mon May 16, 2005 8:50 am    Post subject: Re: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
as dnny told you the PS should be +/-9V, but a +/-12V PS will work just fine as Ray told me. You can find the schematic and the PCB here.
probably Ray was meaning CV inputs for VCO's, VCF's, an so on... but to power up your synth +/-12V PS will be just fine.
ladislao
lanxe
PostPosted: Sun May 22, 2005 6:20 pm    Post subject: Re: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
inverseroom wrote:
Hi there--
Thanks, y'all...
John.
you can use a regular 9v wall wart but you have to add this circuit to get the +/- 9V needed.
its just one chip as shown here:
http://www.geofex.com/circuits/+9_to_-9.htm
its a pretty simple circuit that works pretty well.
Ryan Bocook
dnny
PostPosted: Tue Jul 19, 2005 7:14 am    Post subject: Re: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
Ryan Bocook
that chip is hard to find at least here in Finland
- so here is an alternative schematic. it uses two CMOS hex inverters (74HC04). the maximum output current is 10mA so its perfect for Sound Lab as the SL draws well under 10 mA
Get negative rail using CMOS gates
hope this helps someone
daniel
etaoin
PostPosted: Wed Jul 20, 2005 10:00 pm    Post subject: Re: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
Hmm last time I checked mine pulled a (comparatively) whopping 35mA. Guess something is definitely wrong with mine...
dnny
PostPosted: Thu Jul 21, 2005 12:36 am    Post subject: Re: Using a Wall Wart, and capacitor equivalents Reply with quote  Mark this post and the followings unread
hmm... any LEDs you are using ?
have you moded yours ?
etaoin
PostPosted: Thu Jul 21, 2005 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
One LED on the LFO. No other mods.
But I also experience drops in the +9V of about 20 mV over an LFO cycle (see my 'LFO bleeding into noise generator' thread on this forum).
There's definitely something wrong with my Soundlab, but I can't for the life of me find what it is, which is a pity, since the Soundlab has now been sitting unused on a shelf for weeks after I gave up finding what's wrong with it.
Wild Zebra
PostPosted: Thu Jul 21, 2005 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
So you never figured it out. I was wondering. I unhooked the led for my LFO because even if it wasn't patched it sounded like the LFO was on.
I think because of the voltage the LED was drawing. When I unhooked it it worked fine. I heard of using a buffer and seperate power supply haven't gone that route yet.
"your stripes are killer bro"
