today> Bill Fox solo tonight! Chez Mosc
Randomizing parameters via MIDI?
Page 1 of 1 [4 Posts]
rhombus
PostPosted: Sat May 09, 2015 3:27 am    Post subject: Randomizing parameters via MIDI? Reply with quote  Mark this post and the followings unread
What I'm trying to accomplish here is to send out a set of random MIDI CC values on a single button press.
It's easy enough to do this with a RndPattern and a single send, or a random LFO, etc. However, I'd like to be able to send different random numbers to multiple CCs in an efficient way, hopefully using only one generator.
I've tried using a Mux1-8 with an envelope attached to Ctrl and my generator into the input but each of the Mux's outputs returns the value to 0 when it's not selected. This has the effect of sending out 0 values to the MIDI CCs.
Any ideas on how to solve this little problem?
View user's profile Send private message AIM Address MSN Messenger
Tim Kleinert
G2 patch files: 236
PostPosted: Sat May 09, 2015 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
If you don't want to resort to more expensive solutions requiring S/H modules, this is the only way I can think of doing it.
Basically I clock a shift register module for 1 millisecond, which fills the registers with 8 new random values coming from a noise source. (1000ms/12000*8=0.66ms)
It has one drawback though, in that a minute amount of spurious random CC messages is sent at first before things settle in.
I patched it "dry" in the editor without the hardware connected. See if it works.
EDIT: Technique in next post is probably superior.
MIDI-CC-RandomTK.pch2
 Filename:  MIDI-CC-RandomTK.pch2
 Filesize:  1.42 KB
 Downloaded:  3923 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Sat May 09, 2015 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Another technique is to scramble one random value with cascaded wave-wrapper modules.
The benefit of this technique is that you can add/remove as many random CC generators as you see fit.
Randomization patched and tested in the demo, MIDI CC modules added "dry" in normal editor.
MIDI-CC-Rand2_TK.pch2
 Filename:  MIDI-CC-Rand2_TK.pch2
 Filesize:  1.7 KB
 Downloaded:  2163 Time(s)
rhombus
PostPosted: Thu May 21, 2015 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, Tim, that's great. I wouldn't have thought of that at all.
