today> Twyndyllyngs Chez Mosc
 Forum index » Instruments and Equipment » Percussa Audio Cubes
Percussa announces new mode in MIDIBridge: Improvisor Mode
Post new topic   Reply to topic Moderators: bschiett
Page 1 of 1 [2 Posts]
bschiett
PostPosted: Tue May 19, 2015 7:01 am    Post subject: Percussa announces new mode in MIDIBridge: Improvisor Mode Reply with quote  Mark this post and the followings unread
We've decided to turn our IMPROVISOR application, which started as a Max/MSP patch, into a C++ application and make it part of MIDIBridge (https://www.percussa.com/2015/05/18/percussa-announces-new-mode-in-midibridge.). As you can see on the image below, you'll be able to select IMPROVISOR as a mode in MIDIBridge.
We've also added an AUDIO button at the top which calls up a dialog box letting you set the audio driver type (ASIO, DirectSound, CoreAudio, etc), buffer size, sample rate, etc. This is an important feature for our modular synth, SYNTHOR, which we're planning to build into MIDIBridge as well.
In short, using IMPROVISOR you can play live generative music by programming patterns into the software and then linking those to AudioCubes, and by then placing AudioCubes next to each other. You can check out some videos here: https://www.percussa.com/audiocubes-improvisor
It will be available for download in the next weeks.
I'd love to hear your feedback on IMPROVISOR and what features you'd like to see for this new mode in MIDIBridge?
You can find more information about the new mode https://www.percussa.com/2015/05/18/percussa-announces-new-mode-in-midibridge.
percussa mSSP - digital modular in a eurorack module - 8 in/4 out @ 48/96/192khz DC coupled - 25+ DSP modules https://www.kickstarter.com/projects/percussa/percussa-micro-super-signal-processor-eurorack-mod
EdisonRex
Audio files: 172
PostPosted: Sun Jun 07, 2015 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a nice development. Glad to see you're working on the software as well as the hardware!
Garret: It's so retro.
