Posted: Mon Jun 01, 2015 11:59 am Post subject:
Shadowrim Subject description: animation
...a bit of a random collection of ideas, tests and experiments, with music put to it (some of it from a recent AIS set). The scenes seemed to have a common theme somehow. The video compression wreaks havoc with some colours and patterns and other artifacts happened which I don't know how to avoid. Also I'm learning how to use all the video tools still...
Nevertheless, I thought it good enough to share. Hopefully I'll get better at this as I go along.
Edit: HD version now uploaded. To view in "high definition", click on the little cog wheel and change the setting to 720p. _________________ Muied Lumens Sub Forum Bandcamp Last edited by robsol on Tue Jun 02, 2015 1:48 pm; edited 1 time in total
Posted: Mon Jun 01, 2015 1:37 pm Post subject:
Lovely imagery, blends well with the suggestive music.
The out-of-focus fluttering/gliding lights were beautiful. The black on white lined cube was a bit scary. _________________ Antimon's Window @soundcloud@Flattrhome - you can't explain music
Ah, so that were the dots and lines you were working on?
Some really nice stuff in there! _________________ Jan
Yes it was. Thanks!
I uploaded a HD version (took almost 7 hours), embedded in the first post. It is very confusing to work with video so I'm not 100% sure it worked... _________________ Muied Lumens Sub Forum Bandcamp
Anyway, so I better do not complain that I can not select 720 dpi eh, and just enjoy it a second time!
Right, will do that _________________ Jan
It seems that some computers, or maybe browsers, won't let you select some of the higher resolutions available. Even if you can, there are still some compression artifarts in there. Oh well. _________________ Muied Lumens Sub Forum Bandcamp
