ARP 2600 Wood Case Info
Page 1 of 1 [5 Posts]
Solar1
PostPosted: Mon Feb 16, 2009 10:25 am    Post subject: ARP 2600 Wood Case Info
Subject description: Looking for original cut sheets for wood/tolex case
Hello folks,
I removed the wood/tolex case from my ARP 2600 about 23 years ago to install the unit in a custom formica studio grade case.
Unfortunately, the wood case was thrown out by mistake by my employee at the time.
I would like to build a new case to the original specs, Does anyone know where I can find the cut sheets to the original case?
Somewhere, someone must have saved that from the ARP company archives?
Any contacts or help would be greatly appreciated.
Anyone with a case only for sale?
Thanks
Electronic battle
PostPosted: Wed Mar 04, 2009 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
One possibility is to get a new wooden case made: here are two companies, one in USA and one in England:
http://synthwood.com
http://www.customsynth.co.uk/
Maybe they can design something based on the existing formica effort.
octavecat
PostPosted: Mon Nov 24, 2014 3:35 pm    Post subject: Re: ARP 2600 Wood Case Info
Solar1 wrote:
Hello folks,
Thanks
Hi Solar1. Did you ever get the case measurements? Can you share?
octavecat
PostPosted: Tue Nov 25, 2014 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
I've created a 3d model of the arp 2601 (orange / black) enclosure. I hope this helps with your effort to recreate the case. I'm using it to build a eurorack case matching the same form factor next to my 2601.
 Filesize:  174.05 KB
 Viewed:  749 Time(s)
Arp 2601.dwg.zip
Arp 2601 3d file (dwg format)
 Filename:  Arp 2601.dwg.zip
 Filesize:  29.43 KB
 Downloaded:  888 Time(s)
Solar1
PostPosted: Fri Jul 03, 2015 6:25 am    Post subject: case dimensions 2600 Reply with quote  Mark this post and the followings unread
no, I have never been able to find anyone with a 2600 whom would allow me to measure it accurately.
