Another Mysterious tube thing: amp, Supro-Electro 1247
Page 1 of 1 [5 Posts]
debterminer
Audio files: 9
PostPosted: Mon Aug 10, 2015 2:10 pm    Post subject: Another Mysterious tube thing: amp, Supro-Electro 1247
Subject description: Supro 1247
It consists of:
2x radiotron 42's
One 4 pin sylvania mystery tube
with "Sylvania c6" written on it
(i suspect it is a rectifier)
1 Sylvania 6N7G
Amp is called "Supro electric #1247"
and two transformers, one for input(I assume) and another for electricity.
Additionaly it came in a cab which has a transformer
(The output transformer i presume) built onto the speaker.
Some pictures:
debterminer
Audio files: 9
PostPosted: Mon Aug 10, 2015 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
From some further research, i've been able to determine that this amplifier is from 1936
BobTheDog
Audio files: 32
PostPosted: Fri Aug 14, 2015 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Does it work? Sounds like?
debterminer
Audio files: 9
PostPosted: Fri Aug 14, 2015 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im not turning it on until i've finished moving my electronics lab to my new house where i can properly work on it, It appears to ahve all original components(possibly even the tubes) So im not so sure about just turning it on until i know how to test each component in it for a failure that would normally show up as an firey paper capacitor lol. Also dont yet have a proper schematic for it, though i may have one that is roughly identical. Talking to a guy whos an expert on valco/supro amps about it, as i want to get it running, not blow it up XD.
Airlock
Audio files: 53
PostPosted: Sat Aug 22, 2015 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do a trace off the power supply: old amps can have iffy design choices that can kill, as can be seen in the attached:
 Filesize:  54.22 KB
 Viewed:  278 Time(s)
