filter feedback patch
Page 1 of 1 [10 Posts]
Vader77
PostPosted: Fri Sep 25, 2015 9:04 am    Post subject: filter feedback patch
Subject description: patch needed
On my old AN1X I fond the filter feedback function very useful for fattening up the VCO sound and giving the tone a more analogue feel.
I seem to recall ages ago seeing some patch diagram somewhere to replicate this feature on the Nord Modular.
Does anyone have a link to the patch diagram or better still a preset for the patch itself?
cheers
daksha
PostPosted: Thu May 12, 2016 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi! I have both the An1x & the NM G1, so I understand what you want to do...and I think is possible. The graph at pag. 69 in the AN1x manual shows the signal path...and shouldn't be so difficult to be implemented. Anyway, realizing it depends from the elements in the patch you are working on.
An1x Feedback signal path.
 Filesize:  11.45 KB
 Viewed:  8648 Time(s)
daksha
PostPosted: Thu May 12, 2016 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
A mixer with a free input before the filter section should do the trick Wink
lamptablecomputer
PostPosted: Wed Jun 08, 2016 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.cim.mcgill.ca/~clark/nordmodularbook/nm_filters.html#analog
just dont forget the level inverter in the feedback path
daksha
PostPosted: Thu Jun 09, 2016 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for the suggestion! As I'll be home I will try it...I'm an NM newbie, I was reading the suggested page and example but it doesn't explain why he used the inverter over the feedback signal...could you please in few words explain me the theory behind this? (I suspect there is a very common and basic rule behind this, but I started right now studying this things in detail)
Thanks again!
-Windows 8.1 Pro 64bit DAW (Asus P6T Deluxe V2 + Xeon W3670)
-Steinberg Cubase 8.5 64bit + Steinberg CC121 Controller
-Steinberg MR816 CSX + Behringer ADA8200
-MOTU MicroLite
-Virus TI2 P0lar
-Waldorf Pulse
-Roland Aira TB3
-Yamaha AN1x
-Clavia Nord Modular G1 Expanded
-Axoloti
-Maschine Mikro MK2
-Adam A7X with Nanopatch+
http://soundcloud.com/daksha
lamptablecomputer
PostPosted: Thu Jun 09, 2016 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Filters induce a phase shift, its just to correct this phase shift in the feedback path. Short answer is, if you dont put an inverter it wont work.
daksha
PostPosted: Thu Jun 09, 2016 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot Very Happy
I will try with my synth (and hears) as soon as I'll have the NM in front of me!
-MOTU MicroLite
-Virus TI2 P0lar
-Waldorf Pulse
-Roland Aira TB3
-Yamaha AN1x
-Axoloti
-Maschine Mikro MK2
daksha
PostPosted: Wed Jun 15, 2016 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I've tryed and am a bit perplex about results...with the inverted signal in feedback I have a kind of attenuation over the global signal, without inverter I have a stronger signal, more similar to the result with the An1x.
But it was late night, so maybe I did something wrong...I'll try today from scratch with a new patch.
-MOTU MicroLite
-Virus TI2 P0lar
-Waldorf Pulse
-Roland Aira TB3
-Yamaha AN1x
-Axoloti
-Maschine Mikro MK2
lamptablecomputer
PostPosted: Wed Jun 15, 2016 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Oops, looks like it may be a flub on my part! Ive only made this patch with a clipping module in the feedback path to emulate "analog feel" and the phase shift is from the symmetrical clipping (duh) not the filter. Sorry for the confusion on my part.
daksha
PostPosted: Thu Jun 16, 2016 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Very Happy No problem at all !
Trials & errors are generally the biggest part of the game Wink
-MOTU MicroLite
-Virus TI2 P0lar
-Waldorf Pulse
-Roland Aira TB3
-Yamaha AN1x
-Axoloti
-Maschine Mikro MK2
