Troubleshooting Ultimate Repeat Gate
Page 1 of 1 [12 Posts]
JanneI
PostPosted: Mon Oct 19, 2015 2:08 am    Post subject: Troubleshooting Ultimate Repeat Gate Reply with quote  Mark this post and the followings unread
Hi all!
I just finished my first diy synth project, ultimate+expander. Everything seems to work fine, except the repeat gate.
1) IC oscillates as should, I checked with an oscilloscope as described in the mfos troubleshooting docs
2) I checked the parts and wiring, everything is as should
What it does is... on a high gate all 3 oscillators detune downwards tiny bit and there's also a noticeable ground loop -type of sound. At low gate (0v) everything goes back to normal. Really annoying.. :-/
Any ideas what could solve this? I really like the synth otherwise!
Janne
 Filesize:  75.41 KB
 Viewed:  335 Time(s)
PostPosted: Mon Oct 19, 2015 5:59 am    Post subject: Re: Troubleshooting Ultimate Repeat Gate Reply with quote  Mark this post and the followings unread
welcome Janne
Sounds like there is a short but only when the gate is active .. or at least something drawing too much current then.
What does the power supply look like on the scope with the gate high?
prgdeltablues
Audio files: 12
PostPosted: Mon Oct 19, 2015 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds like that to me too. Try checking you've got the correct values for R220 and R279, and that you haven't got shorts around those.
Peter
PostPosted: Mon Oct 19, 2015 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Definitely sounds like something is loading your supply too much. You don't mention what you're using....
JanneI
PostPosted: Mon Oct 19, 2015 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use Ray's Wall Wart power supply with lm7812/lm7912 and 12vac 500mA wall wart. Should I try 1000mA wall wart instead? I didn't find exact info on current demands for ultimate+expander combo on mfos website.
Thanks all for helping me out!
Janne
JanneI
PostPosted: Tue Oct 20, 2015 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I bought a 12vac 1000mA wall wart and voila! Problem solved!
At first I used Ray's adjustable ac/dc with a 18,5vac x2 0,62a wall wart without problems, but when I boxed the synth I switched the power. Mistakes, best way to learn Wink
Thanks all for helping me! Sometimes it's hard to know where to look if you're a newbie like me Wink
Janne
PostPosted: Tue Oct 20, 2015 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Great news. Probably a good idea to still check those resistor values though...
JanneI
PostPosted: Tue Oct 20, 2015 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I checked all the components, everything seems to work as should! Thanks!
Fun to play with this even without a keyboard! Next step, keyboard controller! Smile
PostPosted: Tue Oct 20, 2015 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah ok. could have been just on the edge with the power supply .. glad you found it :-)
JanneI
PostPosted: Tue Oct 20, 2015 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah ok. could have been just on the edge with the power supply .. glad you found it Smile
https://www.youtube.com/watch?v=KzjSBebi1TA Wink
PostPosted: Tue Oct 20, 2015 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
JanneI
PostPosted: Thu Oct 22, 2015 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
One more Smile
https://www.youtube.com/watch?v=slkRK8cYbY0
