Posted: Wed May 25, 2005 9:42 am Post subject:
PdVST |
I was looking for a way to embed either Keykit or Pd as a VST...just to avoid the overhead of running MIDI Yoke in the background. Looks like someone's been here already!
http://crca.ucsd.edu/~jsarlo/pdvst/
(I still like some of the widgets that Keykit has, so it'd be nice to embed it as a VST as well, if only I were a programmer...) |
Posted: Wed May 25, 2005 2:37 pm Post subject:
Beautifull.
Thanks. _________________ Kassen |
tjt
Joined: Apr 05, 2003 Posts: 32 Location: San Jose, California
Posted: Wed May 25, 2005 8:03 pm Post subject:
Re: PdVST |
I'm not aware of anyone working on such a thing for keykit. Would you want keykit's MIDI output to be sent back to the VST hosting environment? I know that a VSTi can accept MIDI input (obviously), but I'm not sure whether VSTi's can *output* MIDI.
...Tim... |
Posted: Wed May 25, 2005 9:31 pm Post subject:
as of VST 2.0, it supports both MIDI in & out. I don't have a lot of experience with this, and don't know whether or not the VST time stamps are carried with MIDI for sample-accurate timing. Would this be similar to the way OSC works?
I noticed you added OSC to keykit, I'm eager to play with this as I get more networked
But yes, I would like to use keykit's output within my VST host...it puts everything into 1 system that, in theory, could be recalled in it's entirety. |
tjt
Posted: Wed May 25, 2005 10:31 pm Post subject:
| jksuperstar wrote: | | as of VST 2.0, it supports both MIDI in & out. |
Thanks, could be interesting. What kind of things could you do with a VST plugin that aren't possible using MIDI Yoke?
...Tim... |
diskonext
Posted: Thu May 26, 2005 3:23 am Post subject:
I think mainly what jk already pointed out: total recall from within a single environment.
-diskonext _________________ :wq |
Posted: Thu May 26, 2005 8:43 am Post subject:
| tjt wrote: | | jksuperstar wrote: | | as of VST 2.0, it supports both MIDI in & out. |
...Tim... |
Take advantage of the audio routing facilities of your host? I don´t think PD supports rewire so quite a bit of trickery would be needed otherwise.
I think this is a exciting development, I was thinking that I´d need to purchase MAX/MSP because PD was so much harder to intergrate into Live, this one may save me quite a few bucks. _________________ Kassen |
tjt
Posted: Thu May 26, 2005 9:52 am Post subject:
| Kassen wrote: | | tjt wrote: | | jksuperstar wrote: | | as of VST 2.0, it supports both MIDI in & out. |
...Tim... |
Keykit only does MIDI. Doesn't sound like it'd be worth the effort to produce a keykit VST plugin.
...Tim... |
Posted: Thu May 26, 2005 11:12 am Post subject:
| tjt wrote: |
No, not in that case, I was refering to PD. For keyit the only advantage would be convenience. _________________ Kassen |
