today> Twyndyllyngs Chez Mosc
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drones
Gendy-like breakpoints oscillator
Page 1 of 1 [16 Posts]
oljud
PostPosted: Thu Oct 22, 2015 1:47 pm    Post subject: Gendy-like breakpoints oscillator
Subject description: "G2endy" Xenakis-style, dynamic stochastic synthesis
I made a breakpoints-based "dynamic stochastic" oscillator a while back, a'la Iannis Xenakis' Gendy algorithm. It's a bit bare-bones—no interpolation, only 8 breakpoints, no manual initial setting or clamping of individual breakpoints—but I think it gets fairly close, soundwise. You get these weird formants and stuff popping up "from nowhere" and cool noisy stuff.
I've also added a pitch-tracking oscillator, which can follow the envelope of the drone or be amplitude modulated by it, can be synced to it, and which can also frequancy modulate the Gendy oscillator. This gets quite raucous: lots of fun! This addition is what I'm most proud of, it takes the Gendy algorithm to new places. (I think at least in SuperCollider audio-rate modulation of the Gendy-parameteres wasn't possible and feedback of course is very different. I like my nord...)
8 variations and a couple of knob mappings. It gets four voices on my unexpanded Engine and since it's inherently random they make a nice thick wall of noise. It can be thinned out, of course, and can track pitch easily. (although it is by nature not pitch-stable unless you bring down the time-randomness)
In this patch there is no pitch control apart from the knob, I'll make a pure Gendy-version with that later. I couldn't fit the envelope in with the external oscillator in it, and I want to add some possibilities to use the envelope for more than just volume (perhaps resetting the random values, or so). I don't have a midi-keyboard, though, and using the sequencer modules drives me nuts after a while...
(parentheses:
Not sure if this is really a drone or not, couldn't find a "noise" category, or "experimental". I've mostly used it for drones.
Oh, and I used the search function but couldn't find anything regarding Gendy/breakpoints oscillators.
To do:
check if interpolation could fit in somehow
add weighting to the random values (levelscaler, shapers)
modulation..?
a version with individual controls for the breakpoints...
oh, and: is there anyone there? I've been lurking again for the last week or so, not many newer posts. I have a couple of more patches I want to share, so let me know if you like this, that makes me happy)
G2ENDY-oscillator with tracking ext osx (1).pch2
Xenakis-style oscillator. Dynamic stochastic synthesis. Gendy-algorithm. Noise
 Filename:  G2ENDY-oscillator with tracking ext osx (1).pch2
 Filesize:  5.93 KB
 Downloaded:  4311 Time(s)
G2endy demo.mp3
Demoing the G2endy oscillator patch. 4 voices droning on, 8 variations after each other. Some knob twiddling, too.
 Filename:  G2endy demo.mp3
 Filesize:  11.08 MB
 Downloaded:  1171 Time(s)
Audio files: 321
PostPosted: Thu Oct 22, 2015 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is certainly very interesting .. even so much that I didn't get a chance yet to check out your patch or the mp3 Shocked
Heh, instead, after reading about the first sentence in you post I started googling stuff, reading about Gendy and Xenakis and then patching some things for myself to try.
For linear interpolation I ended up using a crossfading multiplexer. The inputs being driven from random LFO speed signals. And indeed, one can do very nice things with this idea ... giving natural sounding, or 'plausible', sounds.
And then suddenly it was bed time Laughing
And yes .. the Nord community has not been very active for .. say .. the last couple of years.
Anyway, I will check out what you did at some later stage, its weekend soon!
Audio files: 321
PostPosted: Fri Oct 23, 2015 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh that sounds pretty wild Laughing
At work now, will need to check the patch later.
oljud
PostPosted: Fri Oct 23, 2015 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad you found some inspiring googling-material!
It does, doesn't it? Twisted Evil
Multiplexers, that's an idea. I've worked more with this kind of complicated clocking-and-routing kind of patch since this so I'm sure I could find a more clever solution. Using modulated sequential AHD envelopes could be a way of getting something similar.
I wouldn't mind taking a look at your patches, I guess you have a different approach than mine.
Audio files: 321
PostPosted: Fri Oct 23, 2015 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
The patch might not quite be what you expected Laughing
Still had no time to look at your patch, had a performance today, in which I actually used the patch above!
On the G2 I would have done about the same thing ... the mirroring as described in the texts I read sofar .. I did not implement that as in my patch the points can not go out of range ... but I guess that mirroring woyld map nicely to wave wrapping.
I can use 12 points in my patch ... but with a proper setup with crossfading multiplexers that could be made longer.
But I should first look at your patch, curious about the tracking thing you described as well.
Electromagnetic Wave
G2 patch files: 38
PostPosted: Fri Oct 23, 2015 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi oljud !
I like this patch ! Very interesting. From my side I checked the patch ... and I googled it after !
I like the work from Iannis Xenakis.
Don't forget this nice tool than you put on your website Smile
http://electro-music.com/patchviewer/?URL=/forum/download.php?id=40587
Smile
Audio files: 321
PostPosted: Sat Oct 24, 2015 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
I had forgotten Shocked thanks Smile
Oh that most certainly is quite different
G2 patch files: 626
PostPosted: Sun Oct 25, 2015 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Love it.
Variation 7 sounds like screeching tires.
oljud
PostPosted: Sun Oct 25, 2015 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi oljud !
Smile
Xenakis did some interesting stuff.
oljud
PostPosted: Sun Oct 25, 2015 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, Wren—I'll try that when I get my PC up and running. Looks cool!
Didn't really follow your patch though. Lots of random generators into a multiplexer—but no synchronisation or random walks?
oljud
PostPosted: Sun Oct 25, 2015 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
ian-s wrote:
Love it.
Thanks! Smile
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Oct 25, 2015 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Very interesting noises from this patch… Thanks for posting it Exclamation
Variation 4 makes a good drone.
Here is something to try… select Variation 5 and then mute the output of the “aux osc”. Then the sound it makes reminds me of some of the strange noises I could get long ago from a short wave radio…
ian-s wrote:
...Variation 7 sounds like screeching tires.
Laughing Yes it does Exclamation
varice
W.T.
G2 patch files: 11
PostPosted: Mon Nov 16, 2015 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
wow! this sounds very interesting!
Something to look forward to when I get home. thumleft
Clavia stuff that I use : expanded Nord rack & NM G2 engine.
W.T.
G2 patch files: 11
PostPosted: Thu Nov 19, 2015 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice patch sir respect
oljud
PostPosted: Tue Dec 01, 2015 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I feel encouraged to put up some other patches now. Cheers
W.T.
G2 patch files: 11
PostPosted: Tue Dec 01, 2015 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good idea Wink
