today> Various Artists September equinox Concert
 Forum index » DIY Hardware and Software » PAIA Equipment
PAiA 3790 Stereo Chord EGG Remake
Page 1 of 1 [4 Posts]
stefanv
PostPosted: Wed Dec 23, 2015 7:43 pm    Post subject: PAiA 3790 Stereo Chord EGG Remake Reply with quote  Mark this post and the followings unread
I recently became interested in the PAiA Chord EGG, a random flowing chord generator based on a 1970s top-octave generator chip. My application was a source of music in an alarm clock, but of course neither the kit nor the TOG chip are available any more.
I decided to undertake a redesign of the Chord EGG, using only off-the-shelf commodity ICs (such as quad op-amps). I stuck to the original architecture wherever possible, but started from scratch in other areas. The end-result is a Chord EGG sound-alike. It uses the same number of chips as the original (5), but they're all the same (TL074 quad op-amps).
I built it on a 7.7" x 3.2" piece of stripboard. If anyone's interested in building their own, there should be enough detail in this article I wrote:
Chord EGG 2015: Remaking a PAiA Classic
There's an audio sample at the end of the article too.
Stefan Vorkoetter
http://www.stefanv.com
varice
Audio files: 29
G2 patch files: 54
PostPosted: Wed Dec 23, 2015 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
I built a PAiA Chord EGG kit (and many other PAiA kits) back in the 70’s. I still have it Exclamation Oh, such fond memories... It is good to see that you are reviving this classic in analog hardware Very Happy
For those with a Clavia Nord Modular G2 or the free G2 Demo software, check this out:
http://electro-music.com/forum/topic-22930
And this topic:
http://electro-music.com/forum/topic-22782.html
varice
DES
PostPosted: Thu Dec 24, 2015 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe the original used the Mostek Top Octive chips, right? I still have 4 or 5 of those lying around....might be fun to cobble a chord egg together...
Can you select the key or is it totally random?
www.davesneed.com
stefanv
PostPosted: Fri Dec 25, 2015 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the original used Mostek (or equivalent chips). I'd hang on to those as a retirement fund. Smile
In the original EGG, the chip is driven by an RC oscillator. I would be easy to make it tunable to let you select the key. But the circuit itself just cycles between the I, IV, and V chords (two inversions of the first) of whatever key it's tuned to.
Of course, you could have a bank of jumpers connecting the TOG to the rest of the circuit, letting you, for example, rewire it for a minor key.
In my remake, the oscillators are individually tuned, so of course it would be possible to retune to a minor key.
Stefan Vorkoetter
