G2 Bank Select on Cubase
Page 1 of 1 [4 Posts]
sonictransportsystem
PostPosted: Sat Feb 27, 2016 8:37 am    Post subject: G2 Bank Select on Cubase Reply with quote  Mark this post and the followings unread
Hi to everyone,
I have a midi track on Cubase and i cant change the banks just the programs even if i change the banks manualy on the synth when i change the program he always go to bank 1... the manual talk about a midi cc32 i think for bank selection... if i need to put this control number on cubase where to put it? Sad
someone can help me
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Feb 27, 2016 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I answered you about this on Fb too before ...
Well on the MIDI track
Here when I record a program change with Cubase on a MIDI track I can see the value on BankSelLSB (cc#32) after I open the MIDI recorded track. After when I playback the track my G2 receive cc#0 + cc#32 + program change. Everything work fine. Be sure everything is setting properly in the 'MIDI filter' page too. Same for the 'System' page with G2.
PostPosted: Sun Mar 06, 2016 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for your help
it seems im starting to figure out ... a lot of technic language so sometimes its dificult to understand when you are not writing or talking on your own language Wink
G2 patch files: 38
PostPosted: Sun Mar 06, 2016 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Wink
I don't speak english very well too. Sometime I don't post what I have in my mind because it's to hard to explain this in english.
This will not solve your problem but I think it's could be a good idea for you to read the help file about the PCSEND module. Especially the Application example at the bottom.
The PCSend module is perfect in combination with the CtrlSend module for sending combined MIDI Bank Select and Program Change messages:
