Lucy
Audio files: 94
Posted: Tue Mar 29, 2016 1:09 am Post subject:
I would put some pitch bending to it and make the sound go slow down and slow up again plus use some modified horn sound to play just one note again and again, to give it a claustrophobic panic like feel, but in a way of timeless with a still standing time. I would like to remix a lot of your stuff, because what I miss in your material is the musical impression of insanity, its a bit to normal for me.
You do more like experimental sounds, but thats also interesting and beautiful. I used to do stuff like that at age 13 or so but it turned out that I prefer more density complexity in sonical layouts. Or ideas that go a bit more into psychedelical insanity. Thats probably the reason why nobody likes my music on internet (laughs).
I respect your stuff, its well produced experimental stuff. Just try to go more over your normal awareness threshold. I bet you will produce great material if you go a bit more into details and beyond your normal sonical threshold. But it was a nice upload. I would put some endless reverb to it and play with a soft echo vibration and filter the sound away and fade it back into the layout. I get so many ideas when I hear your stuff. |
Joined: Apr 03, 2004 Posts: 24664 Location: The Netherlands, Enschede
Posted: Tue Mar 29, 2016 4:59 am Post subject:
Ah .. Crambidae .. nice track :-) _________________ Jan
Posted: Tue Mar 29, 2016 12:26 pm Post subject:
Thanks jan
And thanks Omega for your suggestions. One thing you have to keep in mind is that a lot of things I post are just improvisations
recorded in one take with some DIY gear. I usually don't start out with the intention to record a track, I just play around a bit
patch some things and either record when I start or press record when I hear something I like. Sometimes I do add some things
afterwards but often I just post it unedited. But yeah I would love to go a bit crazier. Maybe you'll like my snotmusic I managed
to get a bit more hectic with that one . (Too bad there was a faulty cable so the stereo cuts out a bit at some points or maybe
that is just a bonus effect)
oh and feel free to remix or sample whatever you want if you hear something you like to use. _________________ "My perf, it's full of holes!"
Posted: Tue Mar 29, 2016 9:56 pm Post subject:
| I like this! What is producing that initial drone? |
Posted: Wed Mar 30, 2016 10:38 am Post subject:
hmm I never make notes of my patches so that is rather hard to say. But I think this was one where I used the sequencial switch
function of my Mad Monkey sequencer and connected the ouputs of a divider to the 4 inputs. The divider was clocked by one of the
main oscillators (audio rate) to create a set of sub-oscillators. And I think I experimented with running the Mad Monkey at LFO and
audio rates. There was probably some more involved though like some filters (maybe also modulated at audio rates) and delays.
Anyway it was done with this synth
